Hay guys I'm steve from ohio I have just purshased a 98 vw beetle Tdi 5 speed. It had some wiring problems that I have fixed.
Now im having problems with starting, ive already bled the fuel system and the engine starts to pick up and run then dies.
No engine lights just a oil light that blinks I checked the oil and is on the full mark. So im here to see if you guys can aid in fixing my issue , and to also learn on how to mod my bug :)
thanks again steve
Check codes as well. The oil pressure sender or wiring could be bad. Of the top of my head, I dont think a blinking oil light means anything else. If you had low oil it should be on all the time and as you've found out, the oil level is fine. If higher engine revs make it go away it might be a worn pump or low oil pressure.
Discussion Starter #4
The car dont really run right now so i couldnt see if the light goes away while in a high rev. I dont think the blinking light would be caused by the wiring , but its a vw who knows. ha
