Hi folks!
I have a 2000 VW Jetta TDI, in Sault Ste. Marie, Ontario, Canada.
I'm the second owner, taking it over in mid 2006, with about 186k km on the odometer. The car is silver, and has been far more reliable than any other car I've owned up to this point (and fun, and gets great mileage when you're nice to it, and decent mileage when you're having too much fun).
I've had a Scangauge II plugged into the machine since the middle of 2008, and it's helped me learn what does and doesn't promote better mileage with the car.
About me: I just wrapped up school, and being in the transition between school and the World of Work again, need to keep it in good running order without the use of an outside mechanic.
My car is now rolling around 325-330k right now (forgot to take a look at it before posting), and it's almost on que for the timing belt as far as mileage goes given the last time I had it done in 2007.
The past month, unfortunately, I've had my share of knocks with the car.
Mid April, a cracked pan on a sewer grate that was half a foot above the pavement, hidden in a puddle gave me a great scare.
And first week of May, the water temperature started rising. As most owners know already, the gauge on the instrument cluster doesn't give much indication of overheating -- the water temperature dial will stay up near the top of the dial through a pretty wide range of temperatures.
That scanguage seems to monitor a different temperature, because it was the only indication that I had a problem brewing, not the normal dial on the cluster. It was steadily, all winter, and well into spring, showing peak operating temperatures around ... 70-72C. Only a series of hill climbs up the escarpment in the middle of town here would make it go a degree or two higher, but that said, the temperature would always moderate to 70C.
The coolant in the overflow reservoir, when fully warmed, is maybe ... 1/2" below the min, and it's been on the slightly low side for some time, alas, but hasn't fluctuated drastically, indicating a coolant leak to cause this.
By mileage alone, I need to change the water pump and timing belt, so I'm embarking on that now.
The dealership out in Alberta, Canada I had the last timing belt done at, did put in a new belt, rollers, tensioner, and metal-impeller water pump, all.
I'm suspecting that there's an issue with the water pump, so the day after it was getting hotter, I parked the car, and it's only been run to put it into my parents' shop so I can do the timing belt on my own. No coolant circulating, then, temperatures will rise.
I certainly don't want to risk the water pump seizing and causing chaos with the rest of the engine as it puts the timing belt in a full stop.
Is there anything else that I should be checking regarding this overheating I had, while I have the car up on blocks? Or after I do the Timing belt/waterpump maintenance?
Thanks for hearing me out so far.
