Got a new car fairly cheap as it had the balance shaft issue, came from a friend so I trusted the engine wasn't completely ruined
After looking into the issue I found a place called kmb parts that seemed to be the place to go for replacement parts. Ordered a new shaft and key way for the oil pump which arrived today.
Not being one for hanging about I set about fixing the car and am pleased to say it's running sweet
This is the balance shaft assembly with the new shaft and key ready to be installed
And here is the part that causes all the drama! Replacement is a good bit longer, you can see on this one where it has worn, clearly doesn't go far enough into the shaft
Seatman changing to Seat Alhambra!!!
You can add that to your car spec.
