All,
I am doing a clutch replacement on a 2001 Jetta TDI. I learned that one can use the VR6 clutch with a single-mass flywheel instead of the stock dual-mass flywheel and clutch. Unfortunately I bought the VR6 flywheel with the VR6 clutch (first mistake). Then I bought a 215 mm flywheel for 92-97 Passat 1.9TD. You can see that here [link edited by chitty ] ---.dieselvw.com/068105269FFlywheel.htm My mechanic said the second flywheel fits the car, but not the VR6 clutch. I understand that the Corrado G60 flywheel works, but I don't want to buy another flywheel that doesn't fit. I think this is the right flywheel http://www.autopartswarehouse.com/d...=P1135867996W43b3f85c7ab9e&gan=1&apwidqDzcu5J , but I'm not sure. Does anyone know if this is the G60 Corrado. Thank you very much in advance for your help.
