I posted a lot on the tdiforums but I'm not getting help so I decided to try over here
I have a BRM that is in limp mode.
The turbo actuator works good with a vacuum pump....... and holds vacuum.
The N75 makes over 25 ??s of vacuum but does not cycle when it should.
no codes
I put an N75 from an ALH on it and it cycles nicely.
When I hooked everything back up to my turbo I still do not get very much boost at all. it goes from 950 mbar to 1140 mbar at wot when it shows that it is asking for much more.
Then I got the code 000665 = Boost Pressure Regulation: Control Range Not Reached
which kinda makes sense. Does this mean that the N75s are different from ALH to BRM or that I have another problem?
for more detailed stuff you can look at my post on the tdiforums....
http://forums.tdiclub.com/showthread.php?t=323392
no codes
