Did you ever remove them? Maybe you connected them backwards? I bet there is a leak somewhere on the vacuum hoses or the N75 valve is bad. Try removing the N75 and cleaning it with carburator cleaner and then WD-40. It could be bad.
yes, today i removed them completly from n75 (hosses) and then car has full boost. I would like to know if anyone had similiar problem, faulty n75 or hoses. will clean it tomorrow, tnxDid you ever remove them? Maybe you connected them backwards? I bet there is a leak somewhere on the vacuum hoses or the N75 valve is bad. Try removing the N75 and cleaning it with carburator cleaner and then WD-40. It could be bad.
i guess egr solenoid would be a thing left from n75, similiar loking, also with vacum hoses?Probably a bad n75 or wires. Do you have an EGR solenoid that you can swap it with? Don't know if your car has the same equipemnt as US cars.
mine are totally differentDid you ever remove them? Maybe you connected them backwards? I bet there is a leak somewhere on the vacuum hoses or the N75 valve is bad. Try removing the N75 and cleaning it with carburator cleaner and then WD-40. It could be bad.
