Hello everyone! I have a 2004 passat tdi 2.0 BHW engine that wont start and run normal after i put new rebuild injectors with new seals,bolts adjusted at 180% The car has heavy start and rough idle.Everything checks out ok(timing,fuel pressure,boost etc.)When shift in gear the engine looses power and sthalls. Does enyone have ideea what could it be the problem. I also put new tandem pump,fuel filter,flush the reservor,clean the egr valve etc..the engine does not have any codes... Thanks. Mike 3104285508:
Were the injectors profesionally done? Do you have the old ones that you could put back in to see if the car runs better?:)
Discussion Starter #4
When cylinder head was rebuild they taped in one of the injector nozzle and damaged it. Then i had to send them to kermatdi to be checked and i was told that i need new nozzles. That's how my problem started.. Tx
