1 - 8 of 8 Posts
I'm working on a '11 Jetta. Had multiple codes related to the DPF. Car goes into limp mode pretty quickly. Took the dpf and CAT off and had them professionally cleaned. Codes are still persistent. Is it possible that one of the many sensors of the DPF has failed? Any other hints as to what the problem might be?
Codes :
P2ba6 How can I isolate in more detail which glow plug is bad?
P2463 DPF cleaned
P0073 (tempt sensor and wiring missing - waiting on new plug)
P0401
P2002
P2463 DPF cleaned
P0401
P2002
VAG Error Code: 011174
EOBD II Error Code: P2BA6
Fault Location:
Unknown Error Code
Possible Cause:
Wiring/Connector(s).
Possible Solutions:
VAG Error Code: 18895/23902/16856/5188/7388/009315
EOBD II Error Code: P2463
Fault Location:
Diesel Particulate Filter (DPF) - Excessive Soot Accumulation
Possible Cause:
Diesel Particulate Filter "full".
Possible Solutions:
Check Diesel Particulate Filter.
Perform Emergency Regeneration.
Read Measuring Value Blocks (MVB) check soot levels.
Special Notes:
Check the repair manual for any Technical Product Information (TPI)/Technical Service Bulletins (TSBs) related to dealer level engine control module software updates and revised replacement parts.
The firmware in the Engine Control Unit (ECU) may very well prevent regeneration when other faults are present, for example this one:
16507 - P0123 - Throttle Position Sensor (G69) - Signal too High.
VAG Error Code: 16457/16473/5568/9859
EOBD II Error Code: P0073
Fault Location:
Ambient (Outside) Air Temperature Sensor (G17) - Signal too High/Short Circuit to Positive
Possible Cause:
Ambient (Outside) Air Temperature Sensor (G17) faulty.
Engine Control Module (ECM).
Possible Solutions:
Ambient Air Temperature Sensor (F38) > 87 °C.
When is the code detected?:
The Engine Control Module (ECM) has detected an open or short circuit condition on the Ambient Air Temperature Sensor (F38) circuit.
VAG Error Code: 16785/001025/4807/7337
EOBD II Error Code: P0401
Fault Location:
Exhaust Gas Recirculation (EGR) System - Insufficient Flow Detected
Possible Cause:
Reduced Exhaust Gas Recirculation (EGR).
Reduced Power Output/Engine running rough.
Increased Emissions.
Hose leak/blockage.
Exhaust Gas Recirculation (EGR) Flow restricted/clogged.
Exhaust Gas Recirculation (EGR) Valve stuck closed/leaking/faulty.
Exhaust Gas Recirculation (EGR) System faulty.
Possible Solutions:
Check/Clean Exhaust Gas Recirculation (EGR) System.
Check/Replace Exhaust Gas Recirculation (EGR) Valve.
Control deviation < limit from map f (engine speed, desired airflow).
Special Notes:
When this fault is stored in a 2009-2012 North American Region (NAR) market 2.0L CR TDI (CBEA, CJAA, CKRA) VW Jetta/Golf (1K/AJ) or the NMS Passat (A3) chassis:
Please see: Technical Service Bulletin (TSB) 26-13-03 | Technical Product Information (TPI) #2031583/3 (formerly know as 26-12-08 | Technical Product Information (TPI) #2031583). When the Exhaust Valve Control Module (J883) is faulty, the engine controller may have any of the following Diagnostic Trouble Codes (DTCs):
P046F, P0477, P048A, P048B, P048C, P0401.
Some TDI-CR engines have a filter for the Exhaust Gas Recirculation (EGR) that can become restricted and cause a "Insufficient Flow" code.
When this fault is stored in a 2009-2014 North American Region (NAR) market 2.0L CR TDI (CBEA or CJAA ) VW Jetta/Golf (1K/AJ).
Please See Technical Product Information (TPI) 01 14 11 | #2034898
May also have fault code stored in Engine Control Module (ECM).
009315/P2463/009315 - Diesel Particulate Filter (DPF) - Excessive Soot Accumulation.
Restrictions in the Exhaust Gas Recirculation (EGR) Filter may occur after a regeneration, if the soot loads where high before the regeneration.
Tech Notes:
Exhaust Gas Recirculation (EGR) flow malfunction could be caused by a clogged Exhaust Gas Recirculation (EGR) valve or Exhaust Gas Recirculation (EGR) tube. Before replacing any parts try cleaning the Exhaust Gas Recirculation (EGR) valve, tube and passages.
Restrictions in the EGR Filter may occur after a regeneration, if the soot loads where high before the regeneration.
VAG Error Code: 19226/18434/008194/5182/5182/5189
EOBD II Error Code: P2002
Fault Location:
Diesel Particulate Filter (DPF) Trap, Bank 1 - Efficiency Below Threshold/Malfunction
Possible Cause:
Exhaust Gas Pressure Sensor 1 (G450) faulty.
Diesel Particulate Filter (DPF) faulty.
Possible Solutions:
Check/Replace Exhaust Gas Pressure Sensor 1 (G450).
Diesel Particulate Filter (DPF).
Perform Emergency Regeneration (Refer to Specifications!).
Check/Replace Diesel Particulate Filter (DPF).
Special Notes:
Skoda Superb (3U) & VW Passat (3B) (Engine Codes: BGW, BSS, BWW) had issues with faulty Exhaust Gas Pressure Sensor 1 (G450), they were defective from factory and due to a leaking sealing the measured values were incorrect and resulted in wrong calculated particle filter load and unsuccessful regeneration cycles.
With CBEA and CJAA engines, the factory documentation may show the wrong part location for the Exhaust Gas Pressure Sensor 1 (G450). This sensor is in a foil pouch just behind the oil cap.
Discussion Starter #5
I must be getting old. I keep thinking I am replying to this post but when follow up i dont see a reply.
Discussion Starter #6
[I just found this reply I wrote a couple weeks ago.
Thanks for taking the time to reply. I'm on dozens of forums and I dont do intros. I dont read them and I assume most other people dont as well. Yes, people often disappear after their problem is solved but that is just the nature of forums. Most people dont make their life from owning a car, they just want to fix it. Then they come back next time it breaks. But its this discourse that often enlightens the knowelge base of the community. Thanks for including the VAG information. I seen most of it during my research of the archives, but the last paragraph got my atten. Now which of the 5 sensorsors on the DPF is sensor 1?
Discussion Starter #7
So, to recap, allot the problems related to this car had to do with the fuel filter. After replacing that I was able to reset the values for the DPF and CAT do a regen. Lights when out and car runs great.
1 - 8 of 8 Posts
