I’m suffering from the occasional overboost and dreaded "Limp Mode". The problem is well documented here for MKIV and earlier TDI's and I am very grateful to all of those who have painstakingly put all of this together. I’m assuming that things are pretty much the same for my BKD engine ( I thinks that’s what it is) I’ve worked through a lot of it and come to the conclusion that it is most likely an actuator problem or sticking vanes.
I have a VCDS and scoped the Turbo boost while the car was being driven on the open road. The resulting scope chart is attached and from my untrained eye it looks like the turbo (yellow line) is a long way off what the engine management system is asking for (green line).
The car is fitted with a Garrett 724930-6. (I have been able to read the model # on the turbo fitted in the car so I know this is correct) From what I understand this is classed and a “non serviceable†turbo. The local Garrett agent tells me that the only option is to buy a new turbo . I have also learned that it is not that the turbo can’t be dismantled just that Garrett do not supply any parts for it, I can’t even buy a new actuator for it apparently! So I have 2 questions:
For the record the car has done 140K kms ( 88K miles) and does most of its running on open roads, very little town driving. It is fitted with a DSG gearbox which, when in “D†changes up very quickly because of the high torque this engine produces. I can only assume that this has meant that the turbo has sooted up as it rarely gets a good blow out. I have tried the “Italian tune†but with limited success, the car tends to be ok for a day or two but will eventually over boost again.
Any help would be greatly appreciated, If I have to spend $2K on a new turbo them so be it but if a strip down and clean is possible and I’m good for another 80K miles then even better.
- 1
- 2
