I'm doing a DPF delete and I dont see the ERG Canister as pictured in the guide I'm following. Instead I have this photo attached. Am I missing something or is this just how the sportswagon is? I linked the guide I'm using as well. I had to skip step 8, I initially thought I would come back to it. Now I'm thinking I just dont have a uper erg bolt. Im doing this on jack stands hoping to finish tomorrow I'm on step 18. The sensor is frozen in il heat it up or something tomorrow to try and get it out. Thanks for the advice in advance.
8650
Did 2 of those forgot. You have block off plate? Want everything from turbo to go outthe back of the car through one pipe. The sensors cannot be installed wrong iirc. I started on some instructions the first time then they blew away and just used common sense. Block off egr get dpf out and good to go. Just reused axle bolts, been fine for 120K miles on this install.
Sent from my Pixel 3 using Tapatalk
Starwind
Release Notes
PM sent.
