1 - 10 of 10 Posts
Evening all,
I have recently bought a used Body Control Module (BCM) to install fog lights to the Mrs's car ...Never again, what a head ache.
All is now installed but the new BCM will not pair to the existing keys and the electrics are doing strange things (the footwell lights won't turn off when driving and are no longer linked to the MFD... but the fogs work). As the key process is straight forward, I have done this several times, I am assuming the BCM is faulty and/or it works on a different frequency to her keys (434mhz), but as the BCM came from the same model of car, in the UK, I doubt it's that
I have tried to return the item, but the seller is saying the BCM may have been blocked. I've tried researching this, but have hit a brick wall. Think the seller might be trying to pull a fast one.
Can anyone please offer any suggestions, or tell me if the BCM can "block" keys from pairing, for whatever reason.
We have confirmed all the coding is correct, as I've gone through each individual byte. The only thing that differs is #19 measuring block, in VCDS, that relates to the alarm and shows an error (again, i'm thinking this is due to a faulty BCM - pictured below).
I've gone from a 1K0 937 084 F (basic) to a 1K0 937 086 (midline),
Any help would be appreciated
Jono
Original Scan (084F)
New Scan (086)
Original BCM
New BCM
Original VCDS Scan
Code:
Wednesday,09,March,2016,15:44:24:62939
Chassis Type: 1K (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 2E 42 44 46 52 56 62 72 77
VIN: WVWZZZ1KZCW082118
01-Engine -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: Sporadic communication error 1000
72-Door, Rear Right -- Status: Sporadic communication error 1000
Address 01: Engine (J623-CFFB)       Labels: 03L-906-018-CFF.clb
   Part No SW: 03L 906 018     HW: 03L 907 309 R
   Component: R4 2,0L EDC   H24 7453
   Revision: 42H24---    Serial number: 00000000000000
   Coding: 00190012042500080000
   Shop #: WSC 01357 011 00200
   ASAM Dataset: EV_ECM20TDI01103L906018 003010
   ROD: EV_ECM20TDI01103L906018.rod
   VCID: E7DDDD171E988F26B59-80B2
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 BJ    HW: 1K0 907 379 BJ
   Component: ESP MK60EC1   H31 0121
   Revision: 00H31001
   Coding: 163B400D092A00FC680C02E590210082310000
   VCID: 7BF51167FA10BBC6C11-802E
Address 08: Auto HVAC (J301)       Labels: 7N0-907-426.clb
   Part No SW: 7N0 907 426 AM    HW: 7N0 907 426 AM
   Component: AC Manuell    H19 0304
   Revision: 00001015
   Coding: 0000004002
   ASAM Dataset: EV_ACManueBHBVW36X A01010
   ROD: EV_ACManueBHBVW36X_SE36.rod
   VCID: 7F0DE577E608A7E6ED9-802A
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 1K0 937 084 F    HW: 1K0 937 084 F
   Component: BCM PQ35  B   110 0651
   Revision: 00110 AC
   Coding: 48180A3A8825F1C0400800C0340081E44B510288536D8160648000200040
   VCID: 3169F34F68DC81962BD-8064
   Subsystem 1 - Part No: 5K2 955 119
   Component: Wischer 25071  26  0512
   Coding: 009795
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 060811 05  54  0403
   Coding: 0230AD
   Subsystem 3 - Part No: 1K8 951 171
   Component: DWA-Sensor 00  001 0104
   Subsystem 4 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
Address 10: Park/Steer Assist (J446)       Labels: 3C8-919-475.clb
   Part No SW: 5K0 919 475 E    HW: 5K0 919 475 E
   Component: PARKHILFE 8K  H01 0012
   Revision: --------    Serial number: 12561119602011
   Coding: 108001
   VCID: 387FCE6B8BA650DE6C3-806D
Address 15: Airbags (J234)       Labels: 5K0-959-655.clb
   Part No SW: 5C0 959 655 B    HW: 5C0 959 655 B
   Component: AirbagVW10    013 0613
   Serial number: 003G5RA8J4LR
   Coding: 00003954
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01014
   ROD: EV_AirbaVW10SMEVW360_VW01.rod
   VCID: 3169F34F60DC81962BD-8064
   Crash sensor for side airbag; driver side:
   Subsystem 1 - Part No SW: 5K0 959 354     HW: 5K0 959 354
   Component: S.Sens.Fahr.V  H01 ----
   Serial number: 3572MSME64321263ZZZK
   Crash sensor for side airbag; passenger side:
   Subsystem 2 - Part No SW: 5K0 959 354     HW: 5K0 959 354
   Component: S.Sens.Beif.V  H01 ----
   Serial number: 3582MSME78447461ZZZZ
   Crash sensor for side airbag; rear driver side:
   Component: S.Sens.Fahr.H  --- ----
   Serial number: 3512QSME624C5E1DZZZ5
   Crash sensor for side airbag; rear passenger side:
   Component: S.Sens.Beif.H  --- ----
   Serial number: 3522QSME52545E09ZZZ-
Address 16: Steering wheel (J527)       Labels: 5K0-953-569.clb
   Part No SW: 5K0 953 507 BC    HW: 5K0 953 549 E
   Component: Lenks.Modul   008 0080
   Revision: --------    Serial number:  90422KH5000CC
   Coding: 1082140000
   ASAM Dataset: EV_SMLSNGKUDS A05001
   ROD: EV_SMLSNGKUDS.rod
   VCID: 72EB3C43A55AFA8E927-8027
   Multifunction steering wheel control module:
   Subsystem 1 - Part No SW: 3C8 959 537 D    HW: 3C8 959 537 D
   Component: E221__MFL-TK6  H06 0022
   Serial number: 40000000000000423311
   Coding: E20000
Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
   Part No SW: 5K0 920 972 A    HW: 5K0 920 972 A
   Component: KOMBI         H03 0607
   Coding: 170B00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
   ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
   VCID: 2E53E83371E29E6E36F-807B
Address 19: CAN Gateway (J533)       Labels: 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 H    HW: 1K0 907 951
   Component: J533  Gateway H42 1620
   Revision:   H42       Serial number: 240711F2002119
   Coding: 350003
   VCID: 3561C75F9CB4ADB6775-8060
2 Faults Found:
01333 - Door Control Module; Rear Left (J388)
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00110100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 88264 km
                    Time Indication: 0
                    Date: 2051.14.17
                    Time: 14:14:21
01334 - Door Control Module; Rear Right (J389)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 88264 km
                    Time Indication: 0
                    Date: 2051.14.17
                    Time: 13:38:37
Address 25: Immobilizer (J334)       Labels: 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H03 0607
   Coding: 000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
   ROD: EV_Immo_UDS_VDD_RM09_VN35.rod
   VCID: EADBA4230D8AB24EAA7-80BF
Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
   Part No SW: 5N0 035 342 E    HW: 5N0 035 342 E
   Component: SG EXT.PLAYER H13 0240
   Revision: A1001003    Serial number: 7660585278
   Coding: 010000
   VCID: 29591B2F400CF956E3D-807C
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.lbl
   Part No SW: 5K0 959 701 B    HW: 5K0 959 701 B
   Component: Tuer-SG         009 2120
   Coding: 0000756
   VCID: 3169F34FA8DC81962BD-8064
1 Fault Found:
00120 - Outside Warning Light/Door exit Light Driver Side
            012 - Electrical Fault in Circuit - Intermittent
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 70     3201
   Revision: 00H20000
   VCID: 3467FA5B57CEB4BE40B-8061
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
   Part No SW: 5K0 959 702 C    HW: 5K0 959 702 C
   Coding: 0001012
   VCID: 3365F94752C0B386591-8066
Address 56: Radio (J0503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 3C8 035 195 G    HW: 3C8 035 195 G
   Component: Radio RCD510  052 0208
   Revision: 00000001    Serial number: VWZ1Z3L6683129
   Coding: 01000400040005
   VCID: 2C57E23B4FFEEC7E18B-8079
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.lbl
   Part No SW: 5K0 959 703 D    HW: 5K0 959 703 D
   Component: Tuer-SG         007 2101
   Coding: 0000208
   Shop #: WSC 01357 011 1012551
   VCID: 3561C75F5CB4ADB6775-8060
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.lbl
   Part No SW: 5K0 959 704 D    HW: 5K0 959 704 D
   Coding: 0000208
   VCID: 3663C05341B2A6AE7EF-8063
Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
   Part No SW: 7P6 035 730 E    HW: 7P6 035 730 E
   Component: TELEFON       H09 2730
   Revision: 1B001001    Serial number: 00007660595977
   Coding: 0A01000000010101
   ASAM Dataset: EV_UHVNA A01015
   ROD: EV_UHVNA.rod
   VCID: 3467FA5B9FCEB4BE40B-8061
End   ---------------------------------------------------------------------
New VCDS Scan
Code:
Tuesday,08,March,2016,16:09:10:62939
Readiness: 0 0 0 0 1
   Revision: 00H31001
   Revision: 00001015
   Coding: 0000004002
   Part No SW: 1K0 937 086     HW: 1K0 937 086
   Component: BCM PQ35  M   020 0358
   Revision: 00020000
   VCID: EDD1AF3F3464A576CF5-80B8
   Coding: 009795
   Coding: 0230AD
2 Faults Found:
00907 - Intervention load Management
            000 - -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 234
                    Mileage: 88660 km
                    Time Indication: 0
                    Date: 2051.14.28
                    Time: 16:05:01
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.75 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
01179 - Incorrect Key Programming
            000 - -
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 234
                    Mileage: 88660 km
                    Time Indication: 0
                    Date: 2051.14.28
                    Time: 16:05:18
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.75 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
   Coding: 108001
   Coding: 00003954
   Coding: 1082140000
   Coding: E20000
   Coding: 170B00
   Coding: 350003
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 88264 km
                    Time Indication: 0
                    Date: 2051.14.17
                    Time: 14:14:21
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 88264 km
                    Time Indication: 0
                    Date: 2051.14.17
                    Time: 13:38:37
   Coding: 000000
   Coding: 010000
   Coding: 0000756
1 Fault Found:
   Revision: 00H20000
   Coding: 0001012
   Coding: 0000208
   Coding: 0000208
   ROD: EV_UHVNA.rod
Fortunately, I found the answer today. Only posted on here, as i'd found many previous threads helpful for this sort of thing.
:) good forum, very wise peeps about
Discussion Starter #4
For anyone searching for the answer.
The "new" bcm is for the pre revised models. Late 2008 to early 2011. Units were generally produced in 2009 or earlier.
For late 2011 models onwards. You need a manufactures date that is 2011 onwards. It's to do with the MFD
As said if you have a genuine VCDS cable then you can register it online VCDS Dongle Registration the you can join the Ross-Tech forum and ask about this problem and post your AutoScan.
Do you know the correct part number of the Body Control Module (BCM) you need to fit your Golf as its no good buying cheap ones of fleabay?
Which engine in is your Mk6 Golf Match, 1.6 or 2.0?
Discussion Starter #6 (Edited)
2011 (61 plate) 2.0 TDI 140 (not bluemotion)
I'm told 1K0 937 086 or 1K0 937 087 with a production date that is 2011 will be compatible.
with letters that end in either; B, D, F, H, K, M, P, R, T. As these are 434mhz frequency, the same
as our keys.
Currently watching ebay item 111846729878, as its the same revision/serial number as the original. S0651
Thanks for the links
Discussion Starter #8
Good start :(
There are a lot of "how to guides" that are wrong on this subject :bangshead. Don't suppose you could point me in the right direction then, could you?
Discussion Starter #9 (Edited)
So, for anyone who comes across this page who is stuck, I've finally cracked it!
As above "1K0 937 086 (midline) or 1K0 937 087 (highline) are the ones which work for fogs.... with letters that end in either; B, D, F, H, K, M, P, R, T. As these, in most cases from reading hundreds of posts, are 434mhz frequency, the same as UK keys. Check your key frequency before buying one.
It is also important that the serial number you choose, circled in red, is equal to or higher than your original unit. Otherwise it will not "talk" to other electrics in the car.
Above is the one I finally got, for the bargain price of £16 delivered. Came out of a Golf GTD, so that proves it doesn't even need to be the same spec of car
Saga over! - Happy fitting.
:thumbsup
:thumbsup
First, thank you for this nice piece of information. I have a serious problem with my BCM, my lcode went wrong and many features were cancelled such as remote control, dashboard lights, door panel lights.
Original lcode: 46180AB8900508C000100080050010E4077000AE620089605C4440200000
Fault lcode: 62E94060DC442020000000AA006000000080000000000000000000000000
I can't add the old code anymore- it always get altered after accepted.
Also, my BCM is 1K0 937 084 and my car is midline (equipped with fogs, bi-xenon, headlight washer). However, you mentioned that 1K0 937 084 is baseline. Please see the code scan below:
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 1K0 937 084 HW: 1K0 937 084
Component: BCM PQ35 B 020 0358
Revision: 00020000
Coding: 62E94060DC442020000000AA006000000080000000000000000000000000
Shop #: WSC 12345 123 12345
VCID: 6BD4FF308A85F11E4F-803E
Subsystem 1 - Part No: 1Z1 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 31100 22 0601
Coding: 00D7B7
6 Faults Found:
01134 - Alarm Horn (H12)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 150
Mileage: 107427 km
Time Indication: 0
Date: 2013.04.25
Time: 14:35:45
Freeze Frame:
Term 15 On
Voltage: 14.05 V
ON
ON
Term 50 Off
OFF
OFF
03152 - Lamp 2 for left Back-Up Light (M76)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 150
Mileage: 107427 km
Time Indication: 0
Date: 2013.04.25
Time: 14:35:45
Freeze Frame:
Term 15 On
Voltage: 14.05 V
ON
ON
Term 50 Off
OFF
OFF
00976 - Indicator Lamp for Heated Windshield (K122)
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 1
Fault Frequency: 5
Reset counter: 190
Mileage: 107427 km
Time Indication: 0
Date: 2013.04.25
Time: 14:37:21
Freeze Frame:
Term 15 On
Voltage: 13.95 V
ON
ON
Term 50 Off
OFF
OFF
01792 - Vacuum Pump (V22); Control to Plus
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 2
Reset counter: 190
Mileage: 107427 km
Time Indication: 0
Date: 2013.04.25
Time: 14:42:25
Freeze Frame:
Term 15 On
Voltage: 14.00 V
ON
ON
Term 50 Off
OFF
OFF
00928 - Locking Module for Central Locking; Front Driver Side (F220)
Freeze Frame:
Fault Status: 01101000
Fault Priority: 4
Fault Frequency: 1
Reset counter: 150
Mileage: 107427 km
Time Indication: 0
Date: 2013.04.25
Time: 15:38:31
Freeze Frame:
Term 15 Off
Voltage: 12.80 V
OFF
ON
Term 50 Off
OFF
OFF
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 150
Mileage: 107427 km
Time Indication: 0
Date: 2013.04.25
Time: 15:38:31
Freeze Frame:
Term 15 Off
Voltage: 12.80 V
OFF
ON
Term 50 Off
OFF
OFF
1 - 10 of 10 Posts
