My dad drove my car and he left a light on. The car would not turn over at all, no clicking nothing but the headlights and dash lights were on. We hooked a portable power pack up and nothing, went to jumper cables for about 15 min and nothing. I had it towed, but am looking for a starting place to narrow this down to what it could be. Thanks, Burt
You need to check out the starter system with a multimeter
Hard starts, seems electrical
You made 2 posts with the same text, I've merged them and deleted the other one.
Checked the battery, good. 12 volts to the starter - nothing when turn the key. No solenoid click nothing. I will check with a generic scanner, but that probably wont show all that the vw one would.
12v while cranking or stationary?
It could be an ignition switch problem.
A generic scanner can give false results.
