1 - 9 of 9 Posts
Hi everyone, I'm just wondering how many motor mounts my 2006 Jetta Tdi has. I looked on rockauto and found many different motor mounts such as front upper, front lower etc. How many do I need just for the motor? Cheers!
2006 Jetta (BRM), 5 speed
I believe there are three, technically. One on each side. Passenger side is visible near the coolant reservoir - this you have to remove to do a timing belt; driver's side, referred to as a Transmission Mount, is under the battery tray, it mounts the transmission side of the motor; and finally you have the transmission pendulum (sometimes called "dog bone") mount - this is found on the bottom of the motor towards the down pipe. There is also a Transmission Support that mounts to the upper Transmission Mount, which I mentioned is below the battery tray.
Here are two pictures from the Bentley manual
Why are you replacing them may I ask? I also have an '06 and I've removed all three of my mounts for various work (timing belt for one, and clutch replacement for other two). In all cases I only replaced the hardware when I reinstalled them (courtesy of kits from KermaTDI). While I love rock auto, and I use it for my other project vehicle, I don't trust it for critical things like motor mounts. Just my two cents.
Discussion Starter #4
I would like to replace them because I'm noticing a lot of shake and vibration coming from the engine. Sometime I'll just be sitting in neutral with the parking brake on and the car it will vibrate a little. I noticed that the rpms stay consistent the entire time, so I think the motor mounts are the culprit. I was told by one of my more mechanically (than me) inclined buddies that it is most likely the motor mounts. That's why I'd like to replace them, thanks!
I posted another response before this one, with descriptions of the mounts and pictures from the Bentley manual, and of course it's waiting moderator approval.
To answer your last response - and someone else can correct me here - these are solid motor mounts. Replacing them will NOT solve what you're describing. It sounds like to me that your DMF (read: dual mass flywheel) may need replaced. Try this: with the motor idling, push in the clutch, does the vibration lessen?
Solid motor mounts, unlike ones that are make of poly something or other, do not prevent shake. It's a diesel, it's going to be a bit rattly. I would venture an educated guess that your issue lies elsewhere than the mounts.
Discussion Starter #6
The shaking itself doesn't happen quite often. It happens once in a grand while. I hear a noise difference when engaging the clutch, but that's about it. The car has 226,000 miles and I have no maintenance records besides the clutch being replaced in may. I bought the car in August.
Discussion Starter #7
Another thing to mention as well is that when it does happens it feels more like a small constant shake. Like the whole car shakes a little.
Gotcha. Well hard to say. If the clutch was replaced, surely the flywheel too (I hope). If they re-used the transmission mount bolts, those could be a culprit. Because the mounts are aluminum, the bolts are not too be raisere-used. There's a way to check that your motor is in the right location (generally it's parallel between the motor mount surfaces). Hard not knowing specifics from a prior owner, or feeling what another TDI is like. Bolts could be loose... I'd check over them in all three locations
Discussion Starter #9
Will do. Thanks so much for all of the information.
1 - 9 of 9 Posts
