1 - 6 of 6 Posts
Hi all. I have a 2009 Jetta TDI (CBEA). A few months ago I got a CEL with a flashing glow plug light. I replaced the glow plug control relay (control module) and the 4 glow plugs. Still has not fixed the issue. My next guess is that it's a harness issue. Anyone ever change the harness on this engine? Looks like I have to splice a new one in. Any tips? Part of my VCDS follows. Apologies in advance for the crazy formatting...still figuring out posting from my mobile.
Address 01: Engine (CBE) Labels: None
5 Faults Found:
001612 - Glow Plug Control Module
P064C - 000 - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 269095 k
Freeze Frame:
RPM: 529 /min
Speed: 0.0 km/h
Voltage: 10.41 V
Temperature: 23.4°
Bin. Bits: 11000000
Time: 0.00 s
Temperature: 21.6°C
P064C - 001 - - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 269095 km
Time Indication: 0
Date: 2000.00.00
Time: 06:48:26
Freeze Frame:
RPM: 529 /min
Speed: 0.0 km/h
Voltage: 10.41 V
Temperature: 23.4°C
Bin. Bits: 11000000
Time: 0.00 s
Temperature: 21.6°C
011174 - Unknown Error Code
P2BA6 - 000 - - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 271340 km
Time Indication: 0
Date: 2000.00.00
Time: 15:18:38
Freeze Frame:
RPM: 1564 /min
Speed: 36.0 km/h
Load: 23.5 %
Pressure: 980.1 mbar
Temperature: 10.8°C
Mass Air / Rev.: 295.0 mg/str
Temperature: 13.5°C
001699 - Sensor Reference Voltage "D"
P06A3 - 000 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 274570 km
Time Indication: 0
Date: 2000.00.00
Time: 10:47:40
Freeze Frame:
RPM: 1357 /min
Speed: 61.0 km/h
Load: 21.2 %
Voltage: 13.53 V
Temperature: 43.2°C
(no units): 0.0
Torque: 78.0 Nm
Readiness: 1 3 0 1 X
5 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 269095 k
Freeze Frame:
RPM: 529 /min
Speed: 0.0 km/h
Voltage: 10.41 V
Temperature: 23.4°
Bin. Bits: 11000000
Time: 0.00 s
Temperature: 21.6°C
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 269095 km
Time Indication: 0
Date: 2000.00.00
Time: 06:48:26
Freeze Frame:
RPM: 529 /min
Speed: 0.0 km/h
Voltage: 10.41 V
Temperature: 23.4°C
Bin. Bits: 11000000
Time: 0.00 s
Temperature: 21.6°C
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 271340 km
Time Indication: 0
Date: 2000.00.00
Time: 15:18:38
Freeze Frame:
RPM: 1564 /min
Speed: 36.0 km/h
Load: 23.5 %
Temperature: 10.8°C
Temperature: 13.5°C
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 274570 km
Time Indication: 0
Date: 2000.00.00
Time: 10:47:40
Freeze Frame:
RPM: 1357 /min
Speed: 61.0 km/h
Load: 21.2 %
Voltage: 13.53 V
Temperature: 43.2°C
(no units): 0.0
Torque: 78.0 Nm
I have same 001612 codes twise, I have this same exact problem what was your fix? mine is a post emission recall car. the issue started about 200 mi after my recall was complete. I installed a new glow plug module but nothing. I was thinking of doing glow plugs next but have not yet. Please let me know of your fix
Manufacturer: VW, Date(s) Used: 07/2007-07/2009, Model: Jetta, Engine Code: CBEA, 103Kw, 140PS, 2.0 Ltr, 4 Cyls, Remarks: Turbocharged Direct Injection Common Rail (TDI-CR) Timing belt
VAG Error Code: 001612
EOBD II Error Code: P064C
Fault Location:
Glow Plug Control Module (GPCM) (J179) - Malfunction
Possible Cause:
Wiring/Connector(s).
Glow Plug.
Glow Plug Control Module (GPCM) (J179).
Engine Control Module (ECM).
Possible Solutions:
VAG Error Code: 011174
EOBD II Error Code: P2BA6
Fault Location:
Unknown Error Code
Possible Cause:
Possible Solutions:
VAG Error Code: 001699
EOBD II Error Code: P06A3
Fault Location:
Sensor Reference Voltage 'D' - Open Circuit
Possible Cause:
Fuse(s).
Possible Solutions:
Check/Replace Fuse(s).
1 - 6 of 6 Posts
