1 - 8 of 8 Posts
Hey guys, I have a 2003 Jetta alh tdi. The car was running great, but just recently the e-brake light would come on and stay on. I changed the e-brake switch, but that didn’t work. So I changed some of the fuses, now when I go to start my car, I’ll turn the key to warm the plugs, and absolutely no lights appear on the dash, then the car will start and die after 2 seconds consistently... I have two key fobs and now the keys don’t work in the door to open them manually, just with the fob button. Any help or advice would be much appreciated!
Sounds like a bad cluster.
You're a newbie here so welcome and I'm sure a mod is gone to chime in and tell you about the FAQ section and give you a few lashings...
Sent from my moto g(7) power using Tapatalk
Maybe when I was messing with the fuses I pulled the cluster fuse? It was running and driving perfectly before I touched any of the fuses
Use a continuity tester to check the fuses. I like a beep to tell me they're good.
Discussion Starter · #5 ·
I ended up going through the whole fuse panel and replacing all of them, just to be sure, still now luck
Discussion Starter · #8 ·
Sorry man, didn’t realize that haha, definitely here to stay, I have 3 vdubs rn lol
1 - 8 of 8 Posts
