Hello everyone, I was wondering if The immobilizer, on a 03 MK4 Jetta 1.9ALH, can be turned off with the Vag com tool? Thanks for any input
As said the immobilizer is set by the ecu, you can't change anything with VAG-COM\VCDS only scan for error codes.
You need to contact a chip tuner they are the only ones that can delete the immobilizer.
