Ok, so I replaced the turbo actuator, (does the car need to "learn" the new one?) cleared the codes. CEL came back on, along with the flashing GPL. Any help would be appreciated.
Here is my VCDS scan:
I will try to also add a logged trip around the neighborhood:
Thursday,04,August,2022,11:44:05:06611
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 22.3.1.4 HEX-V2 CB: 0.4615.4
Data version: 20220407 DS337.0
www.Ross-Tech.com
VIN: 3VW3L7AJ9EM266980 License Plate:
Mileage: 345980km-214982mi Repair Order:
Chassis Type: AJ-VW36 (6N0)
Scan: 01 03 08 09 15 17 19 25 2E 44 56 75 77
VIN: 3VW3L7AJ9EM266980 Mileage: 345980km-214982miles
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
56-Radio -- Status: OK 0000
75-Telematics -- Status: Malfunction 0010
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 997 030 N HW: 03L 907 309 AA
Component: R4 2.0l TDI G000SG 9983
Revision: 12H16--- Serial number:
Coding: 0050072
Shop #: WSC 74291 008 00000
VCID: 392F206FE5580FF3C81-806C
VINID: 0E69C370745A25574218624800B48B3EE3
2 Faults Found:
000175 - Actuator Module for Turbocharger 1
P00AF - 000 - Stuck - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 345980 km
Time Indication: 0
Date: 2016.12.25
Time: 23:37:09
Freeze Frame:
RPM: 805 /min
Speed: 0.0 km/h
Load: 0.0 %
Load: 9.8 %
Lambda: 52.1 %
(no units): 996.0
Temperature: 50.4°C
009571 - Turbocharger Boost Control Position Sensor Circuit
P2563 - 000 - Implausible Signal - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 345980 km
Time Indication: 0
Date: 2016.12.25
Time: 23:38:28
Freeze Frame:
RPM: 828 /min
Speed: 0.0 km/h
Voltage: 13.76 V
Temperature: 186.0°C
Lambda: -28.4 %
Bin. Bits: 00001110
Voltage: 1.900 V
Readiness: 1 1 0 X X
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BS HW: 1K0 907 379 BS
Component: ESP MK60EC1 H46 0166
Revision: 00H46001
Coding: A14B400C49280000851402EC92190042A1100012
Shop #: WSC 47933 001 1048576
VCID: 0451819BDE1A821BEB7-8050
No fault code found.
Address 08: Auto HVAC Labels: 5C0-820-047.clb
Part No SW: 5C0 820 047 BN HW: 5C0 820 047 BN
Component: J301 Klimaanlage 0204
Revision: 2001001S Serial number: 00000001973089
Shop #: WSC 35247 001 1048576
VCID: 6D87C43FE1906353149-8038
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 5C0 937 086 L HW: 5C0 937 086 A
Component: BCM25 JLB M3 H34 0425
Revision: B0034001 Serial number: 06013349130181
Coding: 7B994B1808230F0000382000240884C50082502E60000000300050002000
Shop #: WSC 43256 002 1048576
VCID: 35372C5FC540EB932C9-8060
Subsystem 1 - Part No SW: 6R0 959 801 AN HW: 6R0 959 801 AN Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 006 5461
Serial number: 14102585131219161016
Coding: 820000
Subsystem 2 - Part No SW: 6R0 959 802 AS HW: 6R0 959 802 AS Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 006 5461
Serial number: 14102584131213193752
Coding: 820000
Subsystem 3 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H31 0037
Serial number: 0504415 FLE 20131214
Coding: 020000
Subsystem 4 - Part No SW: 6R0 959 811 M HW: 6R0 959 811 M
Component: J388__TSG_HL 006 5460
Serial number: 14102587131217123910
Coding: 800000
Subsystem 5 - Part No SW: 6R0 959 812 M HW: 6R0 959 812 M
Component: J389__TSG_HR 006 5460
Serial number: 14102586131218202238
Coding: 800000
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 5C0 959 655 AD HW: 5C0 959 655 AD
Component: AirbagVW10 102 0912
Serial number: 003MVD02WY4C
Coding: 00004138
Shop #: WSC 00066 790 00185
ASAM Dataset: EV_AirbaVW10SMEVW360 001026
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 74B1D15B8E3AB29BDB7-8020
Seat occupied recognition:
Subsystem 1 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Component: BF-Gewichtss. H10 0046
Serial number: 6940000Y14000116H401
Coding: 303036
Crash sensor for side airbag: driver side:
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H02 ----
Serial number: 3572MSME452A637FZZZ2
Front Passenger's Side Airbag Crash Sensor:
Subsystem 3 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V H02 ----
Serial number: 3582MSME6A4C4C40ZZZ3
Rear Side Airbag Crash Sensor (on driver's side):
Subsystem 4 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Fahr.H H02 ----
Serial number: 3516KSME4005332AZZZG
Passenger side rear thorax airbag crash sensor:
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Beif.H H02 ----
Serial number: 3526KSME2C2B5B29ZZZ1
Crash sensor for front airbag: driver side:
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Fahr H02 ----
Serial number: 3556LSME28602E2AZZZ
Crash sensor for front airbag: front passenger side:
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Beif H02 ----
Serial number: 3566LSME30522E2AZZZX
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 5C6 920 953 A HW: 5C6 920 953 A
Component: KOMBI H04 0809
Serial number: 00000000000000
Coding: 270A01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04723
ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
VCID: 2B030A271384AD634AD-807E
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 5C0 937 086 A
Component: GW-K-CAN TP20 H34 0425
Revision: B0034001
Coding: 102200
VCID: 70B9DD4BFAA28EBB3FF-8024
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H04 0809
Serial number:
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6A8DCF23DCFE746B71B-803E
Address 2E: Media Player 3
Cannot be reached
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 70 3501
Revision: 00H22000
Shop #: WSC 02069 000 90108
Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 1K0 035 164 F HW: 1K0 035 164 F
Component: LOW NAR SDARS H04 0005
Revision: -----08S Serial number: VWZ4Z6P3715881
Coding: 01000400020006
Shop #: WSC 00066 000 00000
VCID: 2517FC1F75E09B139C9-8070
Address 75: Telematics (J949) Labels:| 12E-035-284.clb
Part No SW: 561 035 285 HW: 561 035 285
Component: OCULowUSA 014 0102
Serial number: 000003554140514
Coding: 02630102C2161A007F1606000000
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_OCULow 001010
ROD: EV_OCULow_001_VW32.rod
VCID: 53F372C76B74D5A322D-8006
1 Fault Found:
2103041 - Control Module
B1788 F0 [009] - Start Prohibition Deactivated
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 8
Fault Frequency: 1
Reset counter: 0
Address 77: Telephone (J412) Labels:| 5N0-035-729.clb
Part No SW: 5N0 035 729 A HW: 5N0 035 729 A
Component: TELEFON H05 0592
Revision: 1B001001 Serial number: 00007665546494
Coding: 0A10030080010110
ASAM Dataset: EV_UHVUMI 001007
ROD: EV_UHVUMI.rod
VCID: 2E0503332096D84B6D3-807A
End----------(Elapsed Time: 01:30, VBatt start/end: 13.7V/13.8V)-----------
LOGGED TRIP:
Discussion Starter · #2 ·
Here is, I think, about a minute of my drive:
Thursday
4​
August
2022​
11:23:51:06611-VCID:392F206FE5580FF3C81-806CVCDS Version: Release 22.3.1Data version: 20220407 DS337.0
03L 997 030 NR4 2.0l TDI G000SG 9983
Group A:'001Group B:'011Group C: Not Running
Engine SpeedInjection QuantityHigh Fuel PressureCoolantEngine SpeedBoost PressureBoost PressureCharge Pressure
TIME(G28)(actual)Temperature (G62)TIME(G28)(specified)(actual)Control Duty CycleTIME
MarkerSTAMP /min mg/str bar°CSTAMP /min %STAMP
0.13​
782​
8.2​
336​
74.7​
0.03​
782​
1008​
1008​
100​
Thursday
4​
August
2022​
11:24:35:06611-VCID:392F206FE5580FF3C81-806CVCDS Version: Release 22.3.1Data version: 20220407 DS337.0
0.08​
1196​
23.9​
784​
73.8​
0.2​
1173​
1212​
1056​
99.6​
0.32​
1173​
24.4​
760​
73.8​
0.45​
1173​
1212​
1068​
97.3​
0.58​
1196​
23.9​
760​
73.8​
0.72​
1219​
1212​
1068​
99.6​
0.84​
1242​
26.1​
776​
73.8​
0.96​
1311​
1332​
1080​
97.3​
1.09​
1380​
23.9​
904​
73.8​
1.21​
1403​
1296​
1080​
95.7​
1.34​
1518​
26.6​
1056​
73.8​
1.48​
1656​
1524​
1092​
92.5​
1.61​
1748​
29.6​
1352​
72.9​
1.75​
1886​
1680​
1128​
90.6​
1.9​
2001​
31.3​
1544​
73.8​
2.04​
2139​
1764​
1188​
89.8​
2.18​
2300​
31.8​
1680​
72.9​
2.32​
2415​
1836​
1260​
92.2​
2.46​
2576​
32.9​
1728​
72.9​
2.59​
2714​
1824​
1380​
84.3​
2.73​
2875​
32.1​
1688​
73.8​
2.87​
3013​
1824​
1488​
73.3​
3.02​
3151​
31.3​
1720​
72.9​
3.16​
3289​
1872​
1548​
73.7​
3.3​
3427​
30.5​
1680​
72.9​
3.44​
3542​
1908​
1560​
68.2​
3.59​
3657​
24.4​
1712​
72.9​
3.72​
3496​
1092​
1524​
65.5​
3.86​
3266​
1.1​
1144​
72.9​
3.99​
2990​
1092​
1308​
76.1​
4.12​
2691​
0.3​
584​
72.9​
4.25​
2300​
1224​
1200​
86.7​
4.37​
2162​
28​
784​
72.9​
4.5​
2093​
2136​
1212​
89.8​
4.62​
2070​
36.2​
1192​
72.9​
4.74​
2139​
2424​
1284​
89.8​
4.89​
2185​
37.3​
1624​
72.9​
5.02​
2231​
2508​
1368​
89.8​
5.16​
2300​
39.5​
1736​
72.9​
5.3​
2346​
2544​
1440​
87.8​
5.44​
2415​
40.1​
1760​
72.9​
5.59​
2484​
2544​
1524​
85.1​
5.72​
2553​
42​
1792​
72.9​
5.86​
2622​
2448​
1620​
78.8​
6​
2691​
44.7​
1792​
72.9​
6.14​
2760​
2376​
1752​
74.1​
6.27​
2829​
47.5​
1816​
72.9​
6.39​
2921​
2340​
1824​
71.8​
6.52​
2967​
46.9​
1824​
72.9​
6.64​
3059​
2316​
1884​
68.2​
6.78​
3128​
46.9​
1824​
72.9​
6.9​
3197​
2292​
1896​
66.7​
7.03​
3243​
46.7​
1824​
72.9​
7.15​
3312​
2256​
1908​
63.9​
7.28​
3381​
43.9​
1816​
72.9​
7.4​
3450​
2196​
1908​
64.3​
7.53​
3496​
39.8​
1792​
72.9​
7.65​
3542​
2064​
1872​
64.3​
7.77​
3588​
34​
1736​
72.9​
7.91​
3611​
1740​
1776​
56.9​
8.06​
3634​
20.6​
1368​
72.9​
8.19​
3634​
1128​
1572​
63.1​
8.33​
3519​
2.7​
888​
72.9​
8.47​
3289​
1092​
1320​
70.2​
8.63​
2967​
0.5​
456​
72.9​
8.77​
2691​
1092​
1176​
89.4​
8.91​
2392​
0​
432​
72.9​
9.05​
2185​
1056​
1140​
95.3​
9.19​
2162​
0​
408​
72.9​
9.33​
2254​
1068​
1104​
95.3​
9.45​
2277​
0​
408​
72.9​
9.57​
2300​
1080​
1080​
94.9​
9.71​
2277​
0​
416​
72.9​
9.85​
2254​
1068​
1068​
94.9​
9.99​
2231​
0​
416​
72.9​
10.13​
2231​
1068​
1056​
95.3​
10.27​
2231​
0​
416​
72.9​
10.41​
2208​
1068​
1056​
95.3​
10.55​
2185​
0​
416​
72.9​
10.69​
2185​
1056​
1056​
95.3​
10.83​
2185​
0​
416​
72.9​
10.97​
2162​
1056​
1044​
95.3​
11.09​
2162​
0​
416​
72.9​
11.22​
2162​
1056​
1044​
95.3​
11.34​
2139​
0​
416​
72.9​
11.46​
2116​
1056​
1044​
95.3​
11.59​
2116​
0​
408​
72.9​
11.71​
2093​
1044​
1044​
95.7​
11.84​
2070​
0​
408​
72.9​
11.97​
2024​
1032​
1044​
95.7​
12.12​
2001​
0​
408​
72.9​
12.25​
1978​
1032​
1044​
95.7​
12.39​
1955​
0​
400​
72.9​
12.53​
1932​
1020​
1044​
96.1​
12.68​
1909​
0​
400​
72.9​
12.81​
1886​
1020​
1044​
96.1​
12.94​
1863​
0​
392​
72.9​
13.06​
1840​
1020​
1044​
96.5​
13.18​
1817​
0​
384​
72.9​
13.31​
1794​
1008​
1044​
96.5​
13.43​
1771​
0​
384​
72.9​
13.57​
1725​
1008​
1044​
96.5​
13.71​
1702​
0​
376​
72.9​
13.85​
1679​
1008​
1032​
96.5​
13.99​
1633​
0​
368​
72.9​
14.13​
1610​
1008​
1032​
96.5​
14.27​
1587​
0​
360​
72.9​
14.41​
1541​
1008​
1032​
96.5​
14.53​
1518​
0​
344​
72.9​
14.67​
1472​
1008​
1032​
96.5​
14.81​
1449​
0​
336​
72.9​
14.95​
1426​
1008​
1032​
96.5​
15.06​
1403​
0​
336​
72.9​
15.19​
1357​
1008​
1032​
96.5​
15.31​
1334​
0​
328​
72.9​
15.44​
1311​
1008​
1020​
96.9​
15.57​
1288​
0​
328​
72.9​
15.7​
1288​
1008​
1020​
96.9​
15.82​
1242​
0​
320​
72.9​
15.95​
1219​
1008​
1020​
97.3​
16.07​
1196​
0​
320​
72.9​
16.19​
1173​
1008​
1020​
97.3​
16.31​
1127​
0​
312​
72.9​
16.44​
1104​
1008​
1020​
97.3​
16.57​
966​
1.1​
304​
72.9​
16.69​
851​
1008​
1032​
100​
16.82​
897​
8.5​
328​
72.9​
16.95​
897​
1020​
1020​
100​
17.07​
920​
7.7​
328​
72.9​
17.19​
920​
1020​
1020​
100​
17.34​
920​
7.4​
328​
72.9​
17.46​
897​
1020​
1020​
100​
17.6​
897​
7.7​
328​
72.9​
17.73​
897​
1020​
1020​
100​
17.85​
897​
8​
328​
72.9​
17.99​
897​
1020​
1020​
100​
18.12​
897​
7.7​
328​
72.9​
18.27​
897​
1020​
1020​
100​
18.41​
897​
7.7​
336​
72.9​
18.55​
897​
1020​
1020​
100​
18.69​
897​
8.8​
336​
72.9​
18.83​
897​
1020​
1020​
100​
18.97​
897​
7.7​
336​
72.9​
19.11​
897​
1020​
1008​
100​
19.25​
897​
7.7​
336​
72.9​
19.39​
897​
1020​
1008​
100​
19.53​
897​
8.5​
336​
72.9​
19.67​
897​
1020​
1008​
100​
19.81​
897​
8.5​
328​
72.9​
19.94​
874​
1020​
1008​
100​
20.06​
897​
8.2​
328​
72.9​
20.2​
897​
1020​
1008​
100​
20.33​
897​
14.3​
336​
72.9​
20.45​
1012​
1068​
1008​
97.3​
20.57​
1035​
11.3​
384​
72.9​
20.7​
1012​
1068​
1008​
97.3​
20.82​
1035​
17​
464​
72.9​
20.95​
1035​
1092​
1020​
97.3​
21.07​
1012​
22.8​
552​
72.9​
21.2​
1058​
1152​
1020​
97.3​
21.34​
1104​
26.4​
664​
72.9​
21.48​
1173​
1440​
1032​
100​
21.62​
1219​
28​
768​
72.9​
21.75​
1311​
1488​
1044​
97.3​
21.88​
1426​
30.5​
984​
72.9​
22.02​
1541​
1560​
1068​
93.3​
22.16​
1656​
30.7​
1272​
72.9​
22.3​
1771​
1644​
1104​
91.4​
22.43​
1886​
30.7​
1472​
72.9​
22.58​
2001​
1680​
1140​
89.8​
22.72​
2093​
29.9​
1584​
72.9​
22.86​
2208​
1704​
1188​
89.4​
22.99​
2323​
28.8​
1664​
72.9​
23.12​
2415​
1704​
1236​
92.2​
23.25​
2507​
27.5​
1672​
72.9​
23.37​
2622​
1644​
1308​
83.9​
23.5​
2714​
25.8​
1640​
72.9​
23.62​
2806​
1656​
1356​
79.6​
23.73​
2875​
25.5​
1608​
72.9​
23.88​
2990​
1668​
1392​
78​
24.02​
3082​
24.7​
1568​
72.9​
24.16​
3174​
1668​
1404​
77.6​
24.3​
3243​
20.9​
1448​
72.9​
24.43​
3243​
1188​
1404​
56.5​
24.58​
3059​
2.2​
952​
72.9​
24.72​
2829​
1092​
1272​
82.4​
24.86​
2553​
0.5​
496​
72.9​
25​
2300​
1212​
1176​
87.5​
25.14​
1978​
22.2​
792​
72.9​
25.28​
1886​
1776​
1188​
90.2​
25.42​
1863​
35.1​
1248​
72.9​
25.56​
1909​
1860​
1236​
89.8​
25.69​
1932​
35.4​
1528​
73.8​
25.81​
2001​
1956​
1284​
89.8​
25.93​
2047​
35.7​
1600​
73.8​
26.07​
2093​
2076​
1320​
89.8​
26.21​
2139​
37.1​
1656​
73.8​
26.35​
2185​
1956​
1368​
89​
26.49​
2231​
36​
1712​
73.8​
26.63​
2300​
1932​
1416​
89.4​
26.77​
2346​
35.1​
1736​
72.9​
26.91​
2392​
1836​
1464​
88.6​
27.05​
2438​
33.5​
1736​
73.8​
27.19​
2484​
1836​
1512​
85.9​
27.33​
2530​
32.4​
1736​
73.8​
27.47​
2576​
1812​
1548​
80.8​
27.61​
2622​
31​
1736​
73.8​
27.75​
2668​
1776​
1572​
76.1​
27.87​
2714​
31​
1720​
73.8​
27.99​
2760​
1752​
1548​
75.3​
28.12​
2806​
28.5​
1704​
73.8​
28.24​
2829​
1716​
1524​
75.3​
28.37​
2852​
26.9​
1672​
73.8​
28.49​
2898​
1668​
1500​
75.7​
28.63​
2921​
25.5​
1616​
73.8​
28.77​
2944​
1620​
1476​
76.5​
28.91​
2990​
22.2​
1544​
73.8​
29.05​
3013​
1584​
1452​
78.4​
29.19​
3013​
20.3​
1456​
73.8​
29.33​
3059​
1512​
1416​
78.8​
29.47​
3059​
17.3​
1304​
73.8​
29.61​
3082​
1464​
1380​
80​
29.76​
3082​
14.5​
1088​
73.8​
29.89​
3105​
1428​
1356​
85.5​
30.04​
3105​
13.2​
976​
73.8​
30.17​
3105​
1380​
1332​
88.2​
30.31​
3128​
10.4​
888​
73.8​
30.45​
3105​
1332​
1308​
88.6​
30.59​
3105​
9.3​
848​
73.8​
30.72​
3105​
1308​
1272​
89.8​
30.84​
3105​
9.1​
848​
73.8​
30.96​
3082​
1308​
1248​
90.2​
31.09​
3082​
9.3​
840​
73.8​
31.2​
3082​
1308​
1236​
89.8​
31.35​
3082​
7.7​
752​
73.8​
31.49​
3082​
1248​
1212​
91​
31.63​
3059​
6.6​
656​
73.8​
31.77​
3036​
1140​
1188​
75.7​
31.91​
3013​
3.6​
576​
73.8​
32.05​
3013​
1140​
1128​
76.5​
32.2​
2990​
3​
560​
73.8​
32.33​
2967​
1140​
1068​
78​
32.47​
2944​
3​
568​
73.8​
32.61​
2921​
1140​
1044​
79.6​
32.76​
2898​
3.6​
568​
73.8​
32.89​
2875​
1140​
1032​
80.8​
33.03​
2852​
2.5​
568​
73.8​
33.17​
2829​
1140​
1032​
82​
33.31​
2806​
3​
568​
73.8​
33.46​
2783​
1152​
1032​
83.9​
33.59​
2783​
3​
576​
73.8​
33.7​
2737​
1104​
1032​
87.5​
33.84​
2737​
0.3​
488​
73.8​
33.97​
2714​
1092​
1032​
89​
34.09​
2691​
0.5​
448​
73.8​
34.21​
2668​
1092​
1032​
89.8​
34.34​
2645​
0.8​
424​
73.8​
34.48​
2645​
1092​
1032​
90.6​
34.62​
2599​
0​
424​
73.8​
34.76​
2576​
1092​
1044​
91.8​
34.9​
2553​
0​
424​
73.8​
35.04​
2530​
1092​
1044​
92.5​
35.18​
2507​
0​
424​
73.8​
35.32​
2484​
1092​
1044​
93.3​
35.46​
2461​
0​
432​
73.8​
35.6​
2438​
1092​
1044​
93.7​
35.74​
2438​
0​
424​
73.8​
35.88​
2392​
1080​
1044​
94.1​
36.02​
2392​
0​
424​
73.8​
36.16​
2369​
1080​
1044​
94.1​
36.3​
2346​
0​
424​
73.8​
36.43​
2323​
1080​
1044​
94.5​
36.56​
2277​
0​
424​
73.8​
36.7​
2254​
1068​
1044​
94.9​
36.82​
2208​
0​
424​
73.8​
36.95​
2185​
1056​
1044​
95.3​
37.07​
2162​
0​
416​
73.8​
37.2​
2116​
1044​
1044​
95.3​
37.33​
2093​
0​
416​
73.8​
37.45​
2047​
1044​
1044​
95.7​
37.57​
2024​
0​
408​
73.8​
37.71​
1978​
1032​
1032​
95.7​
37.85​
1955​
0​
400​
73.8​
37.99​
1909​
1020​
1032​
96.1​
38.13​
1863​
0​
392​
73.8​
38.27​
1840​
1020​
1032​
96.1​
38.42​
1794​
0​
384​
73.8​
38.55​
1748​
1008​
1032​
96.5​
38.7​
1725​
0​
376​
73.8​
38.83​
1679​
1008​
1032​
96.5​
38.97​
1633​
0​
368​
73.8​
39.12​
1587​
1008​
1032​
96.5​
39.25​
1564​
0​
360​
73.8​
39.39​
1518​
1008​
1032​
96.5​
39.54​
1472​
0​
344​
73.8​
39.67​
1449​
1008​
1032​
96.5​
39.81​
1403​
0​
336​
73.8​
39.95​
1380​
1008​
1020​
96.5​
40.09​
1357​
0​
328​
73.8​
40.22​
1357​
1008​
1020​
96.5​
40.34​
1334​
1.4​
328​
73.8​
40.47​
1334​
1032​
1020​
96.5​
40.59​
1311​
6​
512​
73.8​
40.73​
1311​
1188​
1020​
98​
40.86​
1334​
10.7​
856​
73.8​
40.98​
1334​
1728​
1020​
96.1​
41.12​
1357​
25​
952​
73.8​
41.26​
1380​
1800​
1032​
95.3​
41.4​
1403​
29.1​
1016​
73.8​
41.54​
1449​
1908​
1068​
93.7​
41.68​
1495​
30.7​
1128​
73.8​
41.82​
1518​
2028​
1104​
92.9​
41.96​
1564​
32.7​
1232​
73.8​
42.1​
1610​
2148​
1140​
91.8​
42.24​
1656​
33.2​
1328​
73.8​
42.37​
1702​
2256​
1176​
91.4​
42.5​
1748​
34​
1408​
73.8​
42.64​
1794​
2352​
1212​
91​
42.78​
1840​
35.1​
1496​
73.8​
42.93​
1886​
2364​
1248​
88.2​
43.06​
1932​
36.5​
1544​
73.8​
43.2​
1978​
2376​
1296​
89.8​
43.34​
2024​
35.7​
1600​
73.8​
43.46​
2070​
2316​
1332​
87.8​
43.59​
2116​
37.3​
1656​
73.8​
43.73​
2185​
2196​
1368​
88.2​
43.87​
2231​
39​
1704​
73.8​
44​
2277​
2196​
1416​
87.8​
44.15​
2323​
38.7​
1744​
73.8​
44.29​
2392​
2040​
1476​
89​
44.42​
2438​
35.7​
1736​
73.8​
44.56​
2484​
1824​
1536​
81.6​
44.7​
2530​
32.7​
1720​
73.8​
44.83​
2599​
1812​
1536​
79.6​
44.98​
2622​
31.8​
1736​
73.8​
45.12​
2691​
1800​
1536​
77.6​
45.25​
2714​
32.4​
1720​
73.8​
45.39​
2760​
1776​
1536​
76.1​
45.51​
2806​
31​
1728​
73.8​
45.64​
2852​
1764​
1524​
76.1​
45.78​
2875​
29.9​
1712​
73.8​
45.92​
2921​
1716​
1524​
73.7​
46.04​
2944​
25.5​
1608​
73.8​
46.17​
2967​
1572​
1512​
71​
46.29​
3013​
17.8​
1368​
74.7​
46.42​
3036​
1476​
1416​
75.7​
46.57​
3036​
17.3​
1248​
74.7​
46.7​
3036​
1464​
1356​
80.4​
46.82​
3059​
14.8​
1120​
74.7​
46.95​
3059​
1428​
1332​
85.1​
47.07​
3082​
14.3​
1056​
74.7​
47.2​
3082​
1440​
1308​
86.3​
47.33​
3105​
14.3​
1080​
74.7​
47.45​
3082​
1332​
1308​
86.3​
47.59​
3013​
3​
800​
74.7​
47.73​
2829​
1092​
1248​
83.9​
47.87​
2553​
0.5​
456​
74.7​
48.01​
2300​
1080​
1176​
94.5​
48.15​
2116​
3.3​
504​
74.7​
48.29​
2024​
1188​
1140​
87.1​
48.43​
1955​
12.9​
920​
74.7​
48.57​
1978​
1296​
1116​
89.8​
48.71​
1978​
17.6​
1224​
74.7​
48.85​
1978​
1308​
1128​
89.8​
48.99​
2001​
18.1​
1320​
74.7​
49.13​
2001​
1332​
1128​
89.8​
49.27​
2001​
18.7​
1328​
74.7​
49.41​
2001​
1344​
1140​
89.8​
49.55​
2001​
18.7​
1336​
74.7​
49.69​
2024​
1344​
1152​
89.8​
49.83​
2024​
18.4​
1344​
74.7​
49.95​
2047​
1356​
1152​
89.8​
50.1​
2047​
18.7​
1344​
74.7​
50.23​
2047​
1356​
1164​
89.8​
50.35​
2070​
18.4​
1344​
74.7​
50.47​
2047​
1344​
1164​
89.8​
50.61​
2070​
18.7​
1352​
74.7​
50.76​
2070​
1356​
1176​
89.8​
50.9​
2070​
18.7​
1344​
74.7​
51.04​
2093​
1356​
1176​
89.8​
51.18​
2093​
18.4​
1320​
74.7​
51.32​
2093​
1344​
1176​
89.8​
51.46​
2093​
18.4​
1344​
74.7​
51.59​
2116​
1356​
1176​
89.8​
51.74​
2116​
18.1​
1344​
74.7​
51.88​
2116​
1356​
1176​
89.8​
52.02​
2116​
18.4​
1360​
74.7​
52.16​
2139​
1356​
1188​
89.8​
52.29​
2139​
18.1​
1360​
74.7​
52.42​
2139​
1356​
1188​
89.8​
52.54​
2162​
18.1​
1320​
74.7​
52.67​
2162​
1344​
1188​
89.4​
52.79​
2162​
16.2​
1208​
74.7​
52.92​
2162​
1272​
1188​
88.6​
53.04​
2162​
12.4​
984​
74.7​
53.18​
2185​
1188​
1176​
87.5​
53.32​
2162​
9.9​
856​
74.7​
53.46​
2162​
1176​
1140​
88.6​
53.6​
2162​
8.5​
832​
74.7​
53.75​
2162​
1176​
1116​
89​
53.88​
2162​
8​
832​
74.7​
54.02​
2162​
1164​
1104​
89​
54.16​
2162​
8​
816​
74.7​
54.3​
2139​
1164​
1092​
89​
54.44​
2139​
7.7​
808​
74.7​
54.58​
2139​
1152​
1080​
89.4​
54.7​
2139​
6.9​
784​
74.7​
54.85​
2139​
1104​
1080​
86.3​
54.99​
2139​
4.9​
632​
74.7​
55.11​
2116​
1092​
1056​
89.4​
55.25​
2116​
2.7​
528​
74.7​
55.37​
2116​
1068​
1056​
91.4​
55.49​
2093​
2.5​
496​
74.7​
55.63​
2093​
1068​
1044​
91.4​
55.77​
2070​
2.2​
528​
74.7​
55.91​
2070​
1068​
1032​
91.8​
56.06​
2047​
1.9​
504​
74.7​
56.2​
2047​
1056​
1032​
91.8​
56.33​
2047​
1.9​
496​
74.7​
56.47​
2024​
1056​
1032​
91.8​
56.62​
2024​
1.9​
480​
74.7​
56.76​
2001​
1056​
1032​
91.8​
56.89​
2001​
1.9​
488​
74.7​
57.01​
1978​
1056​
1032​
91.8​
57.14​
1978​
2.2​
488​
74.7​
57.26​
1978​
1056​
1020​
91.4​
57.39​
1955​
2.7​
512​
74.7​
57.51​
1955​
1080​
1020​
87.1​
57.64​
1955​
4.1​
592​
74.7​
57.77​
1932​
1080​
1032​
86.7​
57.9​
1932​
6​
656​
74.7​
58.04​
1932​
1104​
1032​
86.3​
58.18​
1932​
7.4​
728​
74.7​
58.32​
1932​
1140​
1032​
87.1​
58.46​
1909​
9.9​
856​
74.7​
58.6​
1932​
1152​
1044​
87.1​
58.74​
1932​
11.8​
936​
75.6​
58.88​
1932​
1236​
1044​
90.6​
59.02​
1909​
14.3​
1064​
74.7​
59.16​
1932​
1248​
1068​
90.6​
59.3​
1932​
15.4​
1128​
75.6​
59.44​
1932​
1260​
1080​
90.2​
59.57​
1932​
15.6​
1136​
74.7​
59.71​
1932​
1260​
1092​
90.2​
59.84​
1955​
15.6​
1152​
75.6​
59.99​
1955​
1284​
1104​
90.2​
60.12​
1955​
16.7​
1200​
75.6​
60.25​
1955​
1284​
1116​
90.2​
No it doesn't need to "learn" the new actuator. It looks like you've got some other issue causing boost to lag behind requested pretty badly. I would start with vacuum lines between the tandem pump and n75 and the n75 and turbo actuator. And also check your range of actuator movement by noting movement by 3 hg and hitting the stop at around 18. . . . or boost side crack or leak in the plumbing .
Discussion Starter · #4 ·
Thank you for your response. Prior to changing the actuator, I did find a vacuum leak in the line for the brake booster, replaced line. I checked all the vacuum lines for the N75, they all hold vacuum. I also found that the charge hose on the intercooler was leaking, changed that O-ring. After installing the actuator, I checked that the movement of the actuator began at around 3", and stopped around 18". I then attempted to conduct the test through VCDS to operate the actuator, but the GPL is flashing and in limp mode.
Is there an easy way to check for leaks on the charge side? i've heard of doing a smoke test but not sure how to conduct...
