Long time lurker, first post....
MIL light came on a few days ago. Steady not blinking. No other warning lights on. Car drives normally. Called dealer, earliest appointment for Friday and said car was fine to drive as long as MIL is steady and not blinking.
Searching past posts found this fault associated with everthing from the software being too sensitive causing the fault and they have a software flash to remedy. Or I also read some reports where they replace the O2 sensors. Or others with EGR issues.
Wondering if anyone has any advice on what the dealer should be doing and how concerned I should be this. Also, this should all be covered under warranty, right? Thanks for the advice. Ill post back after the service visit.
GOLF TDI – DSG bought in March 2010. Door sticker has a build of 1/2010. 8646 miles, garaged at night, live in NJ and has been very cold. Not sure if climate has anything to do with this. Fuel from same Shell station since ownership. No other issues in almost a year of ownership.
Hooked up to VCDS and received this fault:
000315 - Oxygen (Lambda) Sensor B1 S2: Response too Slow Lean to Rich
P013B - 000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Mileage: 13821 km
Time Indication: 0
Date: 2011.14.01
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 13821 km
Time Indication: 0
Date: 2011.14.01
