OK, readers digest version;
My '03 jetta tdi engine bracket broke at the a/c comp. idler pulley. I am in process to put on a new (used) bracket and keep running into other issues.
1) may as well do a timing belt kit while I'm in there,
2) easier to remove egr to access the one valve cover bolt
3) now I can clearly see that the egr/intake are almost clogged so I will be removing and cleaning those,
4)now, the real issue...There is an excessive amount of oil that appears to be being drawn into the turbo and then expelled to the intercooler (which is/was an oily dirty nightmare), then proceeds to the egr/intake (which I am sure is why they are sooo dirty).
WHAT WOULD CAUSE THAT AMOUNT OF OIL TO BE DRAWN INTO THE TURBO???
TIA
Scott
TIA
Scott
