Hi guys/gals.
Now for the first 4-5 months of having my car I put 283 mp3's on a 2GB flash drive in my RCD310 with different groups in different folders. I made a playlist in WMP all random and it worked great. After this time I noticed that the tracks weren't very random even though the random option was selected, in fact it appeared to only play in one sub folder. I formatted the drive and reloaded but still only played one folder. I moved all files into the drives root and deleted the folders and the playlist now it plays as it used to randomly. I don't know why it changed after 5 months.
I found a Volkswagen Media Device Interface (MDI) Firmware Upgrade 0111 KW22-2010, considering this is a firmware update after week 22/2010 I think I may give it a go to see if it cures my problem.
I'm not sure what it means on the site?
Does anyone else have MDI problems? Your thoughts are welcome.
I've said this before this is a useful site to have in your favourites for tricks & tips.
Cheers.
Now both downloads are the same date but the first one has the latest updates but the second has specific versions. I does give the error codes if the version is older then installed.VW MDI KW22/2010 Firmware (primary download site – this will have the latest if there are any updates so if you want a specific version use the link below)
VW MDI KW22-2010 Firmware
(This file needs to be renamed from mdi.bin.kw22-2010.enc to mdi.bin.enc. You may not see the .enc extension so this is nothing to worry about – just remove the version number “.kw22-2010″ and proceed with the update)
Cheers.
