My car, 2010 Seat Leon 1,4 TSI (sorry, gasoline)
Had problems with light, no position on the light switch put on any light, but light on when start engine. Foglight front and back off all time.
The dealer said the car had automatic light. I found the cable to the light switch was off, and plugged on, resulting parklight ON even if I close the car.
The problem was INSIDE the euroswitch. A small slider with contact fingers did not follow the rotation of the switch. Two small taps under the slider was too long and get stuck in other parts below, and lost conection to the rotating shaft. The switch was ok after making the taps 1/10 mm shorter.
I got information on the euroswitch from:
http://www.myturbodiesel.com/1000q/a6/euroswitch-drl-vw-golf-jetta.htm
Thanks for this help.
