1 - 7 of 7 Posts
Trying to work out the software kinks on my 2.0l TDI-CR CBEA to 2005 A4 Swap.
I have a complete wrecked 2009 Jetta CBEA TDI-CR with DSG.
A4 was 3.0l 6spd and of course DSG will not fit the Audi.
Options I have on hand are Original and Still Running ECU for the car w/DSG and ECU for same car with Manual that will not start the (IMMO) active.
My thought is to use the ECU for manual trans, if I car get it to communicate over the Original CAN-Bus. Maybe possible????
But if I cant I will need to use the can module and others from the jetta to make it work. Biggest problem I see is the Cluster I dont think will swap into the dash
Any Input would be great? I know there have ben some CR Swaps out there but mostly into older none Can-Bus cars.
As far as ETKA shows the CBEA is only used in.
Manufacturer: VW, Date(s) Used: 07/2007-07/2009, Model: Bora, Engine Code: CBEA, 103Kw, 140PS, 2.0 Ltr, 4 Cyls, Remarks: Turbocharged Direct Injection Common Rail (TDI-CR) Timing belt
Manufacturer: VW, Date(s) Used: 07/2007-07/2009, Model: Jetta, Engine Code: CBEA, 103Kw, 140PS, 2.0 Ltr, 4 Cyls, Remarks: Turbocharged Direct Injection Common Rail (TDI-CR) Timing belt
Manufacturer: VW, Date(s) Used: 04/2008-06/2009, Model: Jetta Variant, Engine Code: CBEA, 103Kw, 140PS, 2.0 Ltr, 4 Cyls, Remarks: Turbocharged Direct Injection Common Rail (TDI-CR) Timing belt
Manufacturer: VW, Date(s) Used: 04/2008-06/2009, Model: Vento Variant, Engine Code: CBEA, 103Kw, 140PS, 2.0 Ltr, 4 Cyls, Remarks: Turbocharged Direct Injection Common Rail (TDI-CR) Timing belt
Discussion Starter · #3 · (Edited)
That is the point here. Something that you can't just buy.
I already have the ecu communicating with all the stock modules in the a4 over can-bus.
Vss is over can on the 2004 and up Abs modules and does show vehicle speed in data properly on the ecu and cluster.
Immo off will be a must as the generation doesn't match and I don't think it will adapt.
Worked much easier than expected
Discussion Starter · #4 ·
I guess there is no one here that has any knowledge on the 2.0 cr tdi set-ups.
Just finished pin-out diagram for the EDC17cp14 CBEA hope it will help others
2009 Jetta CBEA 2.0 CR tdi
T94/1,2,4 Ground
T94/3,5,6 to power supply relay J317 (pin 87) terminal 30 switched 12v
T94/7 to Exhaust Flap Module J883 pin 4
T94/8 to Accelerator Pedal Module Assembly G79/G185 Pin 5
T94/9 to Exhaust Gas Temp Sensor EGT1 G235 pin 2
T94/11 to Exhaust Pressure Sensor 1 G450 pin 3
T94/13 to Accelerator Pedal Module Assembly G79/G185 Pin 1
T94/14 to Exh Flap Module J883 pin 1 G451 pin 1 G450 pin 1 (d111)
T94/15 to Accelerator Pedal Module Assembly G79/G185 Pin 2
T94/16 to Engine coolant sensor G83 pin 1
T94/17 to MAP Pressure Sensor G31/G42 pin 3
T94/18 to Mass Air Meter G70 pin 1
T94/20 to Glow plug module J179 pin 9/DI
T94/21 to Brake Switch F/F47 pin 1
T94/23 to Mass Air Meter G70 pin 2
T94/29 to Exhaust Flap Module J883 pin 5
T94/30 to MAP Pressure Sensor G31/G42 pin 2
T94/31 to Exhaust Gas Temp Sensor EGT2 G448 pin 2
T94/32 to Exhaust Gas Temp Sensor EGT3 G495 pin 2
T94/33 to Electric Module J519 pin E/2, Brake Switch F/F47 pin3, and ABS (Pin16 w/o esp pin38 w/esp)
T94/34 to Exhaust Pressure Sensor 2 G451 pin 3
T94/39 to Mass Air Meter G70 pin 4
T94/45 to power supply relay (pin 86) terminal 50 and vehicle electric module F/1 and A/11
T94/46 to Fuel pump relay J17 (pin 85) Control
T94/51 to Oxygen Sensor Behind Cat G130 pin 3
T94/53 to Accelerator Pedal Module Assembly G79/G185 Pin 4
T94/54 to Accelerator Pedal Module Assembly G79/G185 Pin 6
T94/55 to Heated Oxygen Sensor G39 pin T6w/5
T94/56 to Heated Oxygen Sensor G39 pin T6w/2
T94/58 to Oxygen Sensor Behind Cat G130 pin 5
T94/59 to Oxygen Sensor Behind Cat G130 pin 2
T94/61 to Glow plug module J179 pin 10/ST
T94/63 to Clutch Position Sensor G476 pin 2
T94/64 to Steering column control module pin 13
T94/65 to Generator T2/2 Starting and Charging
T94/66 to MAP Pressure Sensor G31/G42 pin 1
T94/67 to Can-Bus Low
T94/68 to Can-Bus High
T94/69 to Power Supply relay J317 (pin 85) control term. 30
T94/70 to Cluster pin ? Starting and Charging
T94/73 to Heated Oxygen Sensor G39 pin T6w/3
T94/74 to Accelerator Pedal Module Assembly G79/G185 Pin 3
T94/75 to Exhaust Gas Temp Sensor EGT4 G648 pin 2
T94/76 to Exhaust Flap Module J883 pin 2
T94/77 to Heated Oxygen Sensor G39 pin T6w/1
T94/78 to Heated Oxygen Sensor G39 pin T6w/6
T94/79 to Exh Flap Module J883 pin 3, Exh Pressure 2, G451 pin 2, and Exh Pressure 1 G450 pin 2
T94/80 to Oxygen Sensor Behind Cat G130 pin 1
T94/81 to Oxygen Sensor Behind Cat G130 pin 6
T94/83 to MAP Pressure Sensor G31/G42 pin 4
T94/86 to K-line
T94/87 to Vehicle Electrical System Conrol Module J519 pin L/2 term. 15 Switched power
T94/89 to Engine coolant sensor G83 pin2 and pin 1 on EGTs G235, G448, G495, G648
T94/90 to Cooling Fan T4x/3
T94/92 to fuse SB10 5amp battery constant 12v
T94/93 to Tps N79 pin 2
T60/1 to Fuel Injector 3 N32 pin 1
T60/2 to Fuel Injector 2 N31 pin 1
T60/4 EGR Pot/Vacuum Valve G212/N18 pin 2
T60/6 to Glow Plug 2 Q11 pin 2
T60/10 to Camshaft position sensor G40 PinT3q/1 and Intake runner control G336/V157 pin 1
T60/11 to Throttle valve control module J338 pin 4
T60/15 to Fuel Pump Relay J832 pin 85 control
T60/16 to Fuel Injector 3 N32 pin 2
T60/17 to Fuel Injector 2 N31 pin 2
T60/19 to EGR Pot/Vacuum Valve G212/N18 pin 6
T60/20 to Wastegate Bypass N75 pin 2
T60/21 to Glow Plug 1 Q10 pin 2
T60/22 to Glow Plug 4 Q13 pin 2
T60/23 to Glow Plug 3 Q12 pin 2
T60/24 to Glow Plugs Q10, Q11, Q12, Q13 pin 1
T60/25 to EGR Pot/Vacuum Valve G212/N18 pin1, Engine Speed Sensor G28 pin1,
Fuel quality sensor/ EGR valve 2 G446/N213 pin1, Turbo Wastegate actuator G581 pin3,
Fuel Pressure sensor G247 pin3
T60/27 to Intake runner control G336/V157 pin 2
T60/30 to Throttle valve control module J338 pin 3
T60/31 to Fuel Injector 1 N30 pin 2
T60/32 to Fuel Injector 4 N33 pin 2
T60/34 to Fuel quality sensor/ EGR valve 2 G446/N213 pin 2
T60/35 to Intake runner control G336/V157 pin 4
T60/36 to Glow Plugs Q10, Q11, Q12, Q13 pin 3
T60/40 to Fuel Pressure sensor G247 pin 2
T60/41 to Fuel quality sensor/ EGR valve 2 G446/N213 pin 5
T60/42 to Fuel Temp Sensor G81 pin 2
T60/43 to Coolant Temp sensor G62 pin 1
T60/44 to Camshaft position sensor G40 PinT3q/2
T60/45 to Fuel pressure sensor N276 pin 1
T60/46 to Fuel Injector 1 N30 pin 1
T60/47 to Fuel Injector 4 N33 pin 1
T60/49 to Fuel quality sensor/ EGR valve 2 G446/N213 pin 6
T60/50 to Intake runner control G336/V157 pin 5
T60/51 to Camshaft position sensor G40 PinT3q/3 and Intake runner control G336/V157 pin 3
T60/52 to Engine Speed Sensor G28 pin 2
T60/53 to EGR Pot/Vacuum Valve G212/N18 pin3, Engine Speed Sensor G28 pin3,
Fuel quality sensor/ EGR valve 2 G446/N213 pin3, Turbo Wastegate actuator G581 pin1,
Fuel Pressure sensor G247 pin1, Fuel Temp Sensor G81 pin 1
T60/54 to Egr Temp sensor G98 pin 1 and Coolant Temp sensor G62 pin 2
T60/55 to Egr Temp sensor G98 pin 2
T60/57 EGR Pot/Vacuum Valve G212/N18 pin 5
T60/58 to Charge Pressure Actuator Position Sensor G581 pin 2
T60/60 to Fuel metering valve N290 pin 1
Discussion Starter · #5 ·
Finally found the time to start the swap! Found a nicer 2008 audi A4 S-line.
So far I have completed the automatic to 6 spd swap and rear diff.
Motor is installed, need to finish up fuel and vacuum lines.
I am currently working on the wiring and trying to figure out how to handle the parts i have deleted from the CBEA motor.
The EGR 2 and egr temp sensor behind the motor.
G451 pressure sensor, one lambda sensor behind Dpf. And the temp sensor in it.
Also exhaust flap module assembly
I plan to use a dpf for the Audi A4 tdi from UK.
My question is has anyone deleted the egr and dpf from a jetta or golf with the CR tdi sucessfully and kept the engine light off for inspection and readiness testing.
8984
I've got to say no i don't know how to do anything like what you've been doing and I know several mechanics that I'm sure can't either.
I just want to say I'm so impressed with what you have done It's incredible. You got around all the computer stuff right?
Personally I hate that they put all the computerized stuff on cars now and making them so difficult to work on now.
More power to you ! way to go!!!
Rhonda
Hi just curious..what accessory bracket are you using to be able to add that powersteering pump to the cr140 ?thx
1 - 7 of 7 Posts
