1 - 6 of 6 Posts
I have a 2012 TDI Sportswagon went into limp mode put on a bunch of performance parts . 170 CR turbo .DGS tune ,Malone stage III tune ,EGR cooler ,EGR delete ,rawteck 3 inch exhaust. I use Ross tech my limp mode is boost pressure sensor replaced it that wasn’t it intake manifold pressure sensor replaced it that wasn’t it. Original limp mode was particulate filter clogged ,Soot in turbo, Vehicle was in limp mode prior to performance parts figured I would get rid of all the choking factory parts. I was doing around 75 miles an hour stomped on the brakes in traffic immediately went into limp mode if that is any help thank you any information would be great.
And please don’t chew my ass if I’m posting in the wrong place. Thank you👍
Welcome to the forum.
Release Notes
Limp mode: What is it, what are the causes, and how to fix it for the Audi and VW TDI diesel turbo
Hello Keith I was wondering if you had a chance to do some magic on my vag com diagnostics thank you
Discussion Starter #4
Friday,07,August,2020,23:26:21:43043
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x86
VCDS Version: 20.4.1.0 HEX-V2 CB: 0.4508.4
Data version: 20200331 DS317.0
www.Ross-Tech.com
VIN: 3VWPL7AJ5CM688520 License Plate:
Mileage: 142680km-88657mi Repair Order:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 4F 52 56 62 72
77
VIN: 3VWPL7AJ5CM688520 Mileage: 142680km-88657miles
15-Airbags -- Status: OK 0000
1C-Position Sensing -- Status: OK 0000
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 997 030 E HW: 03L 907 309 AA
Component: R4 2.0l TDI G000AG 9983
Revision: 12H14--- Serial number:
Coding: 0050078
Shop #: WSC 22746 002 1048576
VCID: 3039173A8629D1BBE3B-8064
1 Fault Found:
005522 - Altitude Sensor / Boost Pressure Sensor
P1592 - 000 - Implausible Correlation - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 142687 km
Time Indication: 0
Date: 2014.12.29
Time: 16:22:47
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Voltage: 12.84 V
(no units): 998.4
(no units): 1497.6
Temperature: 16.2°C
(no units): 5.0
Readiness: 1 1 0 X X
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 062 B HW: 02E 927 770 AL
Component: GSG DSG AG6 512 9430
Revision: 05551213 Serial number: 00001202151159
Coding: 0000024
Shop #: WSC 01286 386 08256
VCID: 1471BBAA12710D9BE73-8040
No fault code found.
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Component: ESP MK60EC1 H31 0152
Revision: 00H31001
Coding: 114B600C492A0002881006E692190042B70000
Shop #: WSC 00066 000 00000
VCID: 7DA7FE0E0DFBECD338D-8028
1 Fault Found:
01325 - Control Module for Tire Pressure Monitoring (J502)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 55
Mileage: 142687 km
Time Indication: 0
Date: 2014.12.21
Time: 00:00:29
Freeze Frame:
Count: 2
Count: 12
Count: 20480
Count: 16390
Count: 43264
Count: 0
Count: 509
Count: 0
Address 08: Auto HVAC (J301) Labels:| 3C8-907-336.clb
Part No SW: 7N0 907 426 AN HW: 7N0 907 426 AN
Component: AC Manuell H19 0404
Revision: 00001018
Coding: 0000001002
Shop #: WSC 00066 000 00120
ASAM Dataset: EV_ACManueBHBVW36X A01010
ROD: EV_ACManueBHBVW36X_VW36.rod
VCID: 005987FA7A89813B53B-8054
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 5K0 937 084 J HW: 5K0 937 084 J
Component: BCM PQ35 B 021 3068
Revision: BG021001
Coding: 2F380E1F802F3EC4008800C17000004449000086535D0560648020200040
VCID: 392F2A1E595310F3545-806C
Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 01041 26 0512
Coding: 009795
1 Fault Found:
03266 - Control Circuit for Signal Horn
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 2
Fault Frequency: 23
Reset counter: 55
Mileage: 142686 km
Time Indication: 0
Date: 2014.12.17
Time: 17:22:45
Freeze Frame:
Term 15 On
Voltage: 12.15 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 5K0 959 655 H HW: 5K0 959 655 H
Component: AirbagVW10G 013 0724
Serial number: 003GVRA1L49-
Coding: 00003133
ASAM Dataset: EV_AirbaVW10SMEVW360 A01014
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3FDB440647F73EC36A1-806A
Seat occupied recognition:
Subsystem 1 - Part No SW: 1KM 959 339 B HW: 1KM 959 339 B
Component: BF-Gewichtss. 006 0001
Serial number: ---0000R--00003QGP00
Crash sensor for side airbag: driver side:
Subsystem 2 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME24536163ZZZN
Crash sensor for side airbag: front passenger side:
Subsystem 3 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME704E6163ZZZZ
Crash sensor for side airbag: rear: driver side:
Component: S.Sens.Fahr.H --- ----
Serial number: 3511HSME3C6A252BZZZW
Crash sensor for side airbag: rear: passenger side:
Component: S.Sens.Beif.H --- ----
Serial number: 3521HSME455A402BZZZN
Crash sensor for front airbag: driver side:
Component: F.Sens.Fahr --- ----
Serial number: 35527SME360E092BZZZL
Crash sensor for front airbag: front passenger side:
Component: F.Sens.Beif --- ----
Serial number: 35627SME7805092BZZZJ
Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb
Part No SW: 5K0 953 507 AH HW: 5K0 953 549 B
Component: Lenks.Modul 008 0080
Revision: -------- Serial number: 90440LBN001CI
Coding: 188A140000
Shop #: WSC 00066 000 00186
ASAM Dataset: EV_SMLSNGKUDS A05001
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 76B5E122284DBF8B797-8022
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H09 0013
Serial number: 0144141
Coding: 820000
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 5K0 920 972 C HW: 5K0 920 972 C
Component: KOMBI H03 0607
Serial number: 00000000000000
Coding: 270F01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
VCID: 3039173A8AA9D1BBE3B-8064
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 P HW: 1K0 907 951
Component: J533 Gateway H40 1623
Revision: H40 Serial number: 25031201291321
Coding: 352002
VCID: 3D273E0E4D7B2CD378D-8068
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 5N0 919 879 HW: 5N0 919 879
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1225223RGWB106
Coding: 0000002
VCID: 7EA5F9020CFDF7CB217-802A
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H03 0607
Serial number:
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
ROD: EV_Immo_UDS_VDD_RM09_VW31.rod
VCID: 6A8DC5526CF56B6BEDF-803E
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Component: SG EXT.PLAYER H13 0240
Revision: A1001003 Serial number: 7661742207
Coding: 010000
VCID: 290FFA5EA9F3A073245-807C
Address 42: Door Elect, Driver (J386) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 561 959 701 HW: 3C0 959 793 B
Component: TUER-SG FT 002 0501
Revision: 13110009 Serial number: 0004294496
Coding: 0004B5
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
ROD: EV_TSGFPQ35BRFVW46X_VW36.rod
VCID: 5BE39096B3AF02E3669-800E
Slave Driver:
Subsystem 1 - Part No SW: 3C0 959 703 C HW: 3C0 959 795 D Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 008 1509
Serial number: 00000006521109
Coding: 000490
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 70 3305
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 372B2C2663470683A21-8062
Address 4F: Centr. Electr. II (J520) Labels:. 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 1K0 907 951
Component: EZE_2 H40 1623
Coding: 050B0500
VCID: 6FBBD44657978E43BA1-803A
Subsystem 1 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H03 0220
Serial number: 0123456789ABCDEFGHIJ
1 Fault Found:
02907 - Control Module for Roof Shade (J394)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 55
Mileage: 142686 km
Time Indication: 0
Date: 2014.12.17
Time: 17:22:50
Address 52: Door Elect, Pass. (J387) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 561 959 702 HW: 3C0 959 792 B
Component: TUER-SG BT 002 0501
Revision: 15110009 Serial number: 0004349602
Coding: 0004B4
ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
ROD: EV_TSGBPQ35BRFVW46X_VW36.rod
VCID: 5CE1938AB6A105DB6F3-8008
Slave Passenger:
Subsystem 1 - Part No SW: 3C0 959 704 C HW: 3C0 959 794 D Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 007 1509
Serial number: 00000006344262
Coding: 000490
1 Fault Found:
66048 - Motor for Front Window Regulator
B11EC 54 [009] - Missing Calibration / Basic Setting
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 7
Fault Frequency: 1
Reset counter: 55
Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 1K0 035 180 AE HW: 1K0 035 180 AE
Component: Radio Prem-8 H02 0016
Revision: -----16S Serial number: VWZ4Z7M3275771
Coding: 01000400040007
VCID: 6393A8768B5F3A232E9-8036
Address 77: Telephone (J412) Labels:| 7P6-035-730.clb
Part No SW: 5K0 035 730 E HW: 5K0 035 730 E
Component: TELEFON H12 2902
Revision: 1B001001 Serial number: 00007669673462
Coding: 0A10040000010100
ASAM Dataset: EV_UHVNA A01719
ROD: UHVNA.rod
VCID: 270BFC66BF679603321-8072
End----------(Elapsed T
That is a lot of error codes to bog down an intro.
Your better making a new thread in your vehicles section with the full explanation of the problem with this log file?
1 - 6 of 6 Posts
