1 - 6 of 6 Posts
I change engine , code the injector , i use a used engine with 40000km on. The problem i have now is that only get 2800 omdr.No fault code , no lamp on. I get a used turbo with the engine so i put on. i heard a wisled noise , if i take of the vacum on the solenoid the noise get away. But get fault code , clear the code and put vacum back the arm on the actuator go to the stop schrew , I friend give throtle and i lok at the arm on actuator , is moving only litle , but take of the vacum line the arm move back. Someone som know , i am out of idea now
No error codes scanned with what? A generic scanner or VAG-COM\VCDS?
Sorry for that . Hi from norway and have a wv transporter 4wd 2013 2,0tdi . I get engine havari on 106000km , the engine rev up on the end of the rev , when i drive , i turn of the engine , after that it dosent work longer. I change engine , a used one som have og 40000km. After start up i get fault code on oil temratur sensor , tempratur sensor on particle filtre. I Clear all fault With ross Tech vcd and code the injector. But i get only get 2500 rpm. So i WHAs thinking limp mode , but have not yet test drive , because the snow som coming up her in North, maybe the car have rev limit in stand still position. I shall get Winter tires on and test drive it.
Discussion Starter #5
scanned With vag com and vcd , no fault code, shall test driving
Discussion Starter #6
All ok now , when man have the car in garage and give it full throtle , man only get 2500 omd in neutral. I WHAs thinking limp mode , but i tokk wrong , it are rev limit on newer tdi engine. Have test drive and all ok.
1 - 6 of 6 Posts
