Well, I knew it would happen sooner or later, my wife accidentally left the lights on and drained the battery.
Ouch. Its also pretty easy to not hear the chimes in a loud parking environment.
I noticed that the lights on chime only chimes 5 times when you open the door with the lights on. Is there any way to make that chin more than 5 times?
I bet, like me, you wish the headlights would just turn off when you turn the ignition switch off.
I personally wish the headlights operated like the radio head-unit.
(Turn car off = radio turns off, then tap radio's power power button, radio turns on back on)
My wish is .....turn car off with the headlight switch in the "on" position = everything turns off including the headlights ....then, with the car still off, turn headlight switch off then to back to on position, and the headlights can come back on. Viola! headlights are on and ignition is off.
Well, a boy can dream.......
Check this car battery saver gadget out.
http://www.prioritystart.com/store.html
