Does anyone know the lift pump amperage? The plastic on the fuse to the lift pump was melted, but the fuse portion was not burned through or showing signs of being hot. Still, I had no voltage to the pump. I put a new fuse in and the pump started working again. I want to see what amperage the pump is pulling, and need to know what it should be, to determine if it's going bad or I need to look at something else in the circuit.
