1 - 8 of 8 Posts
Hello ,I'm new to this forum but I hope there's a lot of people who will help . I bought a Seat Leon 1p before 4 months . I have a problem with starting the motor after staying. Sometimes the car is staying without start for 10hrs and the next time when I want to start it it's taking a lot of cranking (sometimes that much that my battery dies) And sometimes it's staying for 1 month without a start and start from 1st crank .... The car is 2.0 tdi PD 140hp BKD engine 2006 . The car is remaped. The car have refurbished turbo and all the injectors are refurbished with new seals. I'm posting a video with the problem -
Please suggest me from where to start looking to fix this annoying problem. THANKS IN ADVANCE.
Are you getting a check engine light or any codes (VCDS)? When was the last time the fuel filter was replaced? Does this car have a lift pump in the fuel tank and is it running when you turn the key on? When it is running does it idle smoothly or is it rough and surging?
No I don't get engine check light also no codes on vcds , fuel filter recently changed and yes when I turn on the key I hear the lift pump . After start it run good all day long no problems.
Thread moved to the correct section as OP can't read sub forum titles. ;)
Discussion Starter #6
Unfortunately I'm not able to reach the car at the moment . I'm in another country at the moment and I'm not able to do a pressure and timing check also vcds scan ,I just wanted to see some suggestions from where to start . I will do these things when I'm with the car and I will post vcds scan codes thanks!
Discussion Starter #7
Hello again. I drove the car to the mechanic again we have changed the lift pump , injectors seals changed again and fuel filter also.We have changed the seals on tandem pump. They put air on air lines and no lose of air from the air lines. the problem still exist ..... Timing and pressure are good.... Here i post the vcds scan but no problems at all...
00-Steering Angle Sensor -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
37-Navigation -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
76-Park Assist -- Status: OK 0000
7D-Aux. Heat -- Status: Malfunction 0010
Address 01: Engine Labels: 03G-906-016-BKD.clb
Part No SW: 03G 906 016 AJ HW: 028 101 173 0
Component: R4 2,0L EDC G000SG A341
Revision: 12345678 Serial number: SEZ7Z0E3149849
Coding: 0050072
Shop #: WSC 00066 001 57865
VCID: 6B4A518CDD34D982AB-803E
1 Fault Found:
16683 - Boost Pressure Regulation
P0299 - 000 - Control Range Not Reached
Freeze Frame:
RPM: 2142 /min
Torque: 154.0 Nm
Speed: 104.0 km/h
Load: 27.1 %
Voltage: 13.83 V
Bin. Bits: 00101000
Absolute Pres.: 2050.2 mbar
Absolute Pres.: 1570.8 mbar
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 Q HW: 1K0 907 379 Q
Component: ESP FRONT MK60 0102
Revision: 00T12001
Coding: 0006786
Shop #: WSC 06441 785 00200
VCID: 4027870FB1EDDBED73-8014
1 Fault Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1P0 907 044
Component: ClimatronicPQ35 001 0302
Shop #: WSC 00000 000 00000
VCID: 694C55B2D522ED8CBB-803C
1 Fault Found:
01274 - Air Flow Flap Positioning Motor (V71)
000 - -
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000003318102
Coding: E38A0F2F00041000001D000000000000000000075C
Shop #: WSC 40332 123 104857
VCID: 2B0AD1CCDD745942AB-807E
Subsystem 1 - Part No: 1P0 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer SE350 012 0403
Coding: 00056272
Shop #: WSC 40332
Subsystem 2 - Part No: 1P0 955 559 Labels: 1P0-955-559.CLB
Component: REGENLICHTSENSORH01 X010
Coding: 00137517
Shop #: WSC 40332
7 Faults Found:
00987 - Lamp for Brake Light; Left (M9)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01111100
Fault Priority: 1
Fault Frequency: 254
Reset counter: 164
Mileage: 211256 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 13.80 V
ON
ON
OFF
OFF
OFF
00988 - Lamp for Brake Light; Right (M10)
Freeze Frame:
Fault Priority: 1
Reset counter: 164
Mileage: 211256 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 13.80 V
ON
ON
OFF
OFF
OFF
02394 - Parking Light Left Front (M1)
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 5
Reset counter: 164
Mileage: 211402 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 11.85 V
ON
ON
OFF
OFF
OFF
02395 - Parking Light Front Right (M3)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 195
Mileage: 211402 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 11.90 V
ON
ON
OFF
OFF
OFF
00984 - Left Tail Light (M4)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 195
Mileage: 211402 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 11.90 V
ON
ON
OFF
OFF
OFF
00447 - Function Limitation due to Over-Voltage
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 195
Mileage: 211419 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 15.70 V
OFF
ON
OFF
OFF
OFF
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Status: 00100010
Fault Priority: 4
Fault Frequency: 4
Reset counter: 204
Mileage: 211696 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 9.20 V
ON
ON
OFF
ON
OFF
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 E HW: 3C0 909 605 E
Component: T7 AIRBAG VW8 027 2421
Revision: 08027000 Serial number: 0039TSEGAU8I
Coding: 0021559
VCID: 280FD7F7D1656BB5B3-807C
Subsystem 1 - Serial number: 6332MSME0B5D393B
Subsystem 2 - Serial number: 6342MSME0A2E6D45
Subsystem 3 - Serial number: 6351HTS68SDI9NB3
Subsystem 4 - Serial number: 6361HTS68SD25M42
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
No fault code found.
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AG HW: 1K0 953 549 AG
Component: J0527 634 0070
Coding: 0002042
VCID: 775E29E8EDF8116E0B-8022
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 004 0060
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1P0 920 840 C
Component: KOMBIINSTRUMENT VO3 0518
Coding: 0004101
Shop #: WSC 00370 128 187160
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 280010570380EF
Coding: 7D3F0FC8070202
VCID: 2A0DD3F1D97F674BA3-807E
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VO3 0518
Address 37: Navigation Labels: 1T0-919-887.lbl
Part No: 1P0 919 887
Component: Navigation 0311
Coding: 0000002
VCID: 7B5A31FC9D8479722B-802E
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX2.lbl
Part No: 1T0 959 701 C
Component: Tuer-SG 024 2451
Coding: 0000176
VCID: 371EA928ED38912E0B-8062
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K1 909 144 J
Component: EPS_ZFLS Kl.5 D04 1606
VCID: 3215A3D9F917B773E3-8066
1 Fault Found:
00778 - Steering Angle Sensor (G85)
000 - -
Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AK
Component: KSG 0401
Coding: 08C000BC090005054C4F861004CC
Shop #: WSC 10580 123 45725
VCID: 795C35E295F20D7C3B-802C
Subsystem 5 - Part No: 1P0 951 171
Component: Innenraumueberw.010 4971
Coding: 00000000
Shop #: WSC 00000
Subsystem 6 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 7 - Component: NGS n.mounted
2 Faults Found:
01135 - Interior Monitoring Sensors
004 - No Signal/Communication - Intermittent
01134 - Alarm Horn (H12)
000 - -
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX2.lbl
Part No: 1T0 959 702 C
Coding: 0000176
VCID: 381FB72791358B2533-806C
Address 55: Headlight Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000009
Shop #: WSC 06403 785 00200
VCID: 74532F93E1E9234113-8020
1 Fault Found:
00070 - Starting Battery Voltage
Address 56: Radio Labels: 1T0-035-095.lbl
Part No: 1T0 035 095
Component: Radio 0311
Coding: 0004402
1 Fault Found:
00857 - CD Changer Unit (R41)
003 - Mechanical Failure
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 G
Component: Tuer-SG 021 2420
Coding: 0000144
VCID: 3413AFD3E129A30113-8060
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 G
Coding: 0000144
VCID: 3510AD2EE526A5181B-8060
Address 76: Park Assist Labels: 1K0-919-283.lbl
Part No: 5P0 919 283
Component: 0M Einparkhilfe 0101
VCID: 75502DEEE5E625581B-8020
Address 77: Telephone Labels: 5P0-862-335.lbl
Part No SW: 5P0 862 335 A HW: 5P0 862 335 A
Component: FSE_2P5x H18 0050
Revision: 00000001 Serial number: 00000000270866
Coding: 0000555
VCID: 3114A5DAF51ABD74FB-8064
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D08DDC6C50E5550DB-8078
1 Fault Found:
00361 - Heater Element for Auxiliary Heater (Z35)
014 - Defective
End-------------------------(Elapsed Time: 02:19)--------------------------
That is a lot off error codes which I won't post until you have made an intro.
1 - 8 of 8 Posts
