2006 VW Jetta TDI
Occasionally, my left rear turn signal will stop working. The dashboard light for a burned out bulb will turn on and the turn signal light will blink quickly. Both are the normal indications for a burned out bulb. However, after a while, this will go away and everything will work fine. I have noticed that most of the time it only happens when I have the headlights on. I replaced the socket that holds the bulbs in place because I thought that it might not have been getting a good connection. However, this has not solved the problem. Does anyone have any ideas? Any help would be appreciated.
Thanks.
Thanks.
