Nice looking wagon, RoadDawg.
Did you mention what tranny you have? I have a 2013 JSW w/ three pedals. But either way, it may be time for a fluid refresh. I'm always interested in best practices to keep her running.
Thanks! Mine's a 6-speed manual. I knocked out changing most the fluids. I still need to do the brake and clutch fluid. It's helpful to hear what others are doing with approximately the same vehicle and miles. I got my JSW with 102K miles, and I've logged an additional 6K. So far so good.
I've been reading about DPF requiring replacement, I suspect that'll be the next big ticket item to be faced in an attempt to keep the car roadworthy. At what mileage did the DPF fail on your car? What other items failed and at what mileage? Starter, alternator, t-stat?
My DPF is still the original. I'm getting a bit more comfortable with using the Ross Tech VCDS, and the measured soot levels I've been seeing over the past month are consistently low - less than 5 grams. The first time I measured the DPF soot accumulation (about 1.5 months ago) it was above 20 grams. This high level was the signal to me that I need to learn about the best ways to drive these vehicles to keep the emission system happy. Here's what I understand thus far:
Periodically put a heavy load on the engine. What this means to me is to do an aggressive acceleration to a near redline RPM level. This will blow out the lines and get exhaust temperatures hot enough to clear what can be cleared. This periodic stress will also often include holding the engine at higher RPMs (3000ish) for a couple minutes to complete the particulate blowout.
What does periodically mean? If I'm city-driving a lot (stop and go with few extended highway miles) I'll purposely give myself a reason to do what I describe in the above paragraph. Regardless of whether I'm city-driving or not, my go-to licensed VW mechanic/race car driver instructor friend tells me he does the above once a day with his diesel vehicles.
Mind you, I'm no expert. But I am having some regular conversations with diesel mechanics and race car drivers. There's no doubt I have a lot more to learn to properly drive these vehicles, but I think I'm on the right track (no pun intended) to reduce carbon and soot build-up.
Last week I followed the guidance laid out in these posts (
reference 1,
reference 2) and cleaned the intake manifold, EGR valve, and throttle valve. The build-up wasn't horrible, but the components needed some clean-up love.
With all this said, I'm still getting engine codes that tell me there are issues with the EGR, DPF, and intake manifold. Hard to know if the VW computer is just being overly sensitive and temperamental. My vehicle performance seems on point - good fuel economy (mid 40s) and no engine stuttering. I'm considering attacking the EGR filter and cooler next.
I haven't touched the alternator, thermostat, or starter. It's probably time to consider the t-stat. Just yesterday I replaced the air conditioner control valve. My AC was inconsistent and not icy cold. I can't remember which MyTurboDiesel post I looked at to lead me to this solution, but the $50 part swap seems to be working. Here's the
reference video on the procedure and part.
