I'm doing my timing belt this morning and have a question about jacking the car (Jetta) up...
I need to remove the passenger side wheel so I clearly can't use ramps. If I jack the right side up using the lift point, where can I put a jackstand? The jack and the jackstand clearly can't both be at the lift point at the same time and I'm damn sure not working under the car if it's only being held up by a jack of any sort.
With my Acura I was able to jack the entire front end up with one floor jack using a central lift point under the engine.
