Hi guys,
I have a Polo 1.9 TDI Sportline(96kw) and I recently did the engine on it. Since then , the car has a starting problem.
When I try to start the car, the engine just swings and sometimes it will start the car but most of the time, I spray a little quick start in the throttle to get the car started.
I had the timing double checked, changed the cam sensor, crank sensor, another mechanic advised that one of the injectors was reading low, replaced the injector, since then the slight miss cleared.
When the car is in motion, it goes well however it sometimes has no power when trying to take off and sometimes switches even switches off, the car also throws out some black smoke when accelerating.
I plugged in a Diagnostic machine and it hasn't picked up any faults.
Any suggestions guys?
Thanks,
Romano.
Which diagnostic machine?
