so i'm about to replace the rear passenger side wheel bearings. i noticed some noise from back there and confirmed when changing the rotor and felt the clunking. I took off the dust cap over the axle nut and a PILE of rust fell out. scary.
Then when i took off the dust cap on the other wheel (rear drivers side) there was no rubber seal or visible grease!
as seen in this picture:
8379
so i'm just going to leave it unless all y'all tell me otherwise.
I also welcome random advice for rear hub/wheel bearing finagling -outside of the How-To on this site. and/or advice for break/rotor changing -all wheels.
-Thanks!
Discussion Starter #2
also why are my new rotors painted?!?
from IDparts.com
"all non contact surfaces painted"
8380
8381
how worried should i be?
I've been advised a few times by 'professionals' to replace both wheel-bearings on an axle if one of them goes. After experiencing problems after replacing brake calipers etc. only on one side and realising that new parts are slightly different sizes (even OEM parts) than the originals, I think it's a pretty good idea. The second one is normally much easier :)
Yours look better than mine did in my 06 when they went bad. I would also recommend you change both at the same time.
