Wobbly tensioner. Replaced tensioner. Still wobbly. Still have noises and squeaks.
Being the tight wad that I am, I went back to my old philosophy of change the least expensive part first. I just changed the serp belt.
Result: ALL noises gone. Most wobbling is gone.
Is it possible that I just needed a new belt?
The car is MUCH quieter!
Won battle; maybe not war.
Jeff:nana2:
Discussion Starter · #2 ·
Philosophy of Alt pulley question
Some folks on these sights have replaced the alt pulley with a clutchless pulley so there is no clutch to break. Seems worth considering.
So if my alt pulley clutch is locked, is it not functioning as a clutchless pulley? Just wondering.
Jeff
No, if the alt pulley clutch is locked, it could be very slightly crooked, enough to send a vibration through the belt system :) Sometimes they lock up, sometimes they slip and move in both directions.
You can replace the alt pulley with a non-clutch pulley. The reason they use this is because it moves the alt smoother and reduces wear...unless it fails :D
Discussion Starter · #4 ·
A guy at a seemingly reputable shop told me the tensioner is supposed to vibrate a little bit because it is self-adjusting. Is that true?
Jeff
