IBased in Cornwall , I have owned a 2006, 2.5 axd vw transporter/ caravelle for 2 years bought with known limp mode problem at a reduced price. Not an awfull lot of service history pretty sure its orginial Turbo.
Mileage: 365300km-226986mi.
If I am driving around b roads and under 70mph doesnt normally go into limp m. However soon as hit some speed especially with a few passangers / weight in the van goes into limp just flick ignition off and on and re-sets itself.
this is part of the scan
16621 - Manifold Pressure / Boost Sensor (G31)
P0237 - 000 - Signal too Low - Intermittent
Freeze Frame:
RPM: 0 /min
Torque: 270.8 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.48 V
Bin. Bits: 00001100
Absolute Pres.: 1326.0 mbar
Absolute Pres.: 2182.8 mbar
16618 - Boost Pressure Regulation
P0234 - 000 - Limit Exceeded (Overboost Condition) - Intermittent
Freeze Frame:
RPM: 3528 /min
Torque: 317.2 Nm
Speed: 116.0 km/h
Load: 96.9 %
Voltage: 14.36 V
Bin. Bits: 00001000
Absolute Pres.: 2111.4 mbar
Absolute Pres.: 2529.6 mbar
16705 - Engine Speed Sensor (G28)
P0321 - 000 - Implausible Signal - Intermittent
Freeze Frame:
RPM: 126 /min
Torque: 285.5 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 9.27 V
Bin. Bits: 00001100
Idle Stabilization: 0.0°KW
RPM: 21 /min
17978 - Engine Start Blocked by Immobilizer
P1570 - 000 - - Intermittent
Freeze Frame:
RPM: 882 /min
Torque: 34.2 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.63 V
Bin. Bits: 00001100
Bin. Bits: 00000000
(no units): 0.0
Ignoring 17978 I have read horror storeys of garages replacing parts until its sorted, starting at cheapst parts and if necessary going right through to a new turbo !!!! I dont have those $$$$
I spoke to a vag mechanic who said he never found a vehicle with a failed n75 !!! but often people change coz easy and 2 seperate vag trained mechanics told me a lot more often, than not, its the stuck turbo veins
Would people agrea a relatively easy way to check would be get under the van and move the actuator rod by hand if stiff hardly moves pretty sure its that and saves alll the testing????????
Have read quite a few reports on using mr muscle squirted inside exhaust side of turbo to unstick the veins without removing turbo from vehicle
I would appreciate any ones experience with this , I realise this has been sort of covered in the past but sometimes its good to start a fresh thread so people with to date problems may get quicker answers.
Sorry for such a Introduction but I have read a lot of good recomendations about this site.
Thanks
Sean
Welcome to the forum.
Make a new thread in general as we don't have a Transporter sub forum, as I don't want to use your intro for your problem.
