Hi all, seem to have an intermittent low pitched noise, sounds a little like a hole in the exhaust, but it’s intermittent?! Seems to last a day or two then don’t hear it for a few weeks. On one occasion my partner said the engine would not switch off.
Otherwise drives normally power wise. Possibly sticking EGR valve?!
Other observations: slight knock from under car over bumps, when engine turns off there is a small motor/ valve that adjusts on the inlet manifold? (Motor is right side of engine)
We can't hear noises on a forum do you have a video of this noise?
Cheers, by the time I got to the car it had stopped again. Would put it down to the Regen, but the partner said the engine would not turn off....
