Hi All,
Story is like this. Couple of weeks ago i got P2015 and P2016 as errors on my manifold. The intake flap motor was dead, manifold was working but it was clogged with carbon quite badly.
I cleared all errors but i still had P2016.
So, I purchased a refurbished manifold and a brand new flap motor, put them all together on the engine, but i still have these errors. Actually the flap is till locked on open and not working at all.
From what a colleague told me, i should do a adaptation to the new flap motor i bought? Would this fix my error?
thanks for the advice.
Address 01: Engine Labels: 03L-906-022-CBA.clb
Control Module Part Number: 03L 906 022 LF HW: 03L 906 022 G
Component and/or Version: R4 2,0L EDC G200SG 3691
Software Coding: 0000071
Work Shop Code: WSC 00191 264 15243
VCID: 74E73A5B174EF4BE80B-8021
3 Faults Found:
008196 - Intake Manifold Flap; Bank 1
P2004 - 000 - Stuck Open - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 5
Reset counter: 255
Mileage: 210811 km
Time Indication: 0
Date: 2022.14.16
Time: 18:26:08
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Load: 100.0 %
Lambda: 97.8 %
Mass Air / Rev.: 0.0 mg/str
Temperature: 78.3°C
008198 - Intake Manifold Flap; Bank 1
P2006 - 000 - Stuck Closed - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100000
Fault Priority: 2
Fault Frequency: 4
Reset counter: 255
Mileage: 210812 km
Time Indication: 0
Date: 2022.14.16
Time: 19:24:34
Freeze Frame:
RPM: 1380 /min
Speed: 54.0 km/h
Load: 36.9 %
Load: 15.3 %
Lambda: 22.1 %
Mass Air / Rev.: 375.0 mg/str
Temperature: 77.4°C
008213 - Intake Manifold Flap Position Sensor (Bank 1)
P2015 - 000 - Implausible Signal
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 210818 km
Time Indication: 0
Date: 2022.14.16
Time: 19:35:42
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Lambda: -11.8 %
Lambda: 0.0 %
Voltage: 3.724 V
Bin. Bits: 10001110
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 255
Mileage: 210811 km
Time Indication: 0
Date: 2022.14.16
Time: 18:26:08
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Load: 100.0 %
Lambda: 97.8 %
Temperature: 78.3°C
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 255
Mileage: 210812 km
Time Indication: 0
Date: 2022.14.16
Time: 19:24:34
Freeze Frame:
RPM: 1380 /min
Speed: 54.0 km/h
Load: 36.9 %
Load: 15.3 %
Lambda: 22.1 %
Temperature: 77.4°C
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 210818 km
Time Indication: 0
Date: 2022.14.16
Time: 19:35:42
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Lambda: -11.8 %
Lambda: 0.0 %
Voltage: 3.724 V
Bin. Bits: 10001110
