I need help, I want to instal a timing belt in my 05 passat, i got a kit from dieselgeek, but i dont have any instructions and it seems i can't access the intallation instructions on this site, any and all help will be much appreciated!
is there any tricks or problems that might come upWelcome! They don't give out instructions with the parts. It takes a few minutes for the first post to be recognized so take your time and read part 1 before you try to access part 2: http://www.myturbodiesel.com/1000q/b5/oil-pump-passat-tdi-replacement.htm
FYI, this is also a good time to check the camshaft for wear and consider replacing the balance shaft with the more reliable gear driven module:http://www.myturbodiesel.com/1000q/b5/oil-pump-failure-passat-tdi.htm
welcometomyturbodies
welcometomyturbodies Welcome to the website - but you really should have posted your own introduction rather than tagged along with someone else's thread...is there any tricks or problems that might come up
