I have a 99.5 jetta that has been intermittently cutting out and stalling.
If I wait 20-30 min it will restart. Some time it doesn't die on the road if I keep the
Clutch ingaged in gear for 5-10 seconds while it's cutting out
It will then resume like nothings wrong. It's been getting more
Frequent. Use to start after about an hour of cruising but now it's
Doing it on short trips around town. The pump timing fluctuates
From about 54-68 and is not stable like my other 2 tdi's.
Could this be a sign of the injection pump going out. Is ther a way
To check the pump with vcds? No leaks on the pump.
Are these rebuildable? The fuel quanity runs at 3.4 at idle.
