After a challenging timing belt job, it seems like the immobilizer will not let me start the vehicle. The care continues to start immediately and then die. Pulled codes with VCDS (which I am still getting used to) and this is what I got:
3 Faults Found:
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
16612 - Throttle Pedal Position Sensor (G79): Signal too High
P0228 - 35-00 - -
17656 - Start of Injection Timing Regulation: Control Deviation
P1248 - 35-00 - -
Must be immo, right?
Now trying to match the key and the immo (immo 3 btw). Followed the tutorial here but am getting hung up with WSC, date , and importer #. Can't login. Did not aniticipate that being a problem as I don't recall that being in the tutorial. Any help with this would be great. 2002 Golf mk4 alh. Thanks.
3 Faults Found:
P0228 - 35-00 - -
P1248 - 35-00 - -
