ok got this vag-com to work this is what it said
VAG-COM Version: Release 409.1-S
Gateway does not exist or CAN interface required.
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01: Engine
Controller: 3B0 907 557 A
Component: 1,6l R4/2V SIMOS HS D02
Coding: 04001
Shop #: WSC 00000
2 Faults Found:
00537 - Lambda (Oxygen Sensor) Regulation
19-10 - Lower Limit - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
Readiness: N/A
Address 03: ABS Brakes
Controller: 8E0 614 111
Component: ABS 5.3 FRONT D11
Coding: 0273004132
Shop #: BB 24303
No fault code found.
Address 15: Airbags
Controller: 8A0 959 655 B
Component: Airbag V AUDI D01
Coding: 00766
Shop #: WSC 06324
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments
Controller: 8D0 919 035 S
Component: B5_KOMBIINSTRUMENT D09
Coding: 00442
Shop #: WSC 00000
Address 25: Immobilizer
Controller: 4A0 953 234 F
Component: IMMO AUZ9Z0T9970259 D77
Coding: 00000
Shop #: WSC 00899
Address 35: Centr. Locks
Controller: 8LO 862 257 A
Component: ZV-Pumpe, DWA
Coding: 01416
Shop #: WSC 06325
8 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch: Driver's Side
35-00 - -
01372 - Alarm triggered by Door Contact Switch: Passenger Side or Rear
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01373 - Alarm triggered by Radio Ground Contact
35-00 - -
