1 - 6 of 6 Posts
There is no immobilizer cable by the starter. The starter is a very simple device - it just requires the battery cables and the wires for the solenoid, the small piece on the starter. I think that is what you are referring to. The small wires can be repaired and they will work fine.
someone tried to break into my 99 beetle.pulled the handle off and door lock out of door.was able to crawl thru trunk to open door.Tried to start car but will barely run for a second or two then shut off.whats the cheapest way to get it running?
1 - 6 of 6 Posts
