I've had a read through the FAQ's but still have a couple of questions
I have
01 B5.5 Passat AWX (not sure if its imo 2 or 3)
1 OEM key with immo RFID chip
1 Plastic key blade (i pressume this has the SKC code but no RFID chip I haven't checked)
I would like another 1-2 keys. Cutting the keys is fine i just have a couple of other questions.
1. Do I need the SKC code to enable keyless entry on the second fob. I presume not just go through the procedure key 1 ignition key 2 door lock etc.
2. If I have the SKC and imo 2 can I disable the imo through VCDS
3. If I have the SKC and imo 3 can I disable the imo through VCDS
4. If I have the SKC and imo 2 can I get a RFID chip and enable it through VCDS.
5. If I have the SKC and imo 3 can I get a RFID chip and enable it through VCDS.
Discussion Starter #2
Ok I think I've found the answers I need on the Ross tech site.
For immo 2 I can add an RFID chip to the imo
For immo 3 I can do the same however it needs to be either new or set by VW
I'm not really interested in disabling it however I have a RFID chip so I could take this out and locate it close to the antenna coil and just cut two keys and program the keyless entry however I would like to keep the immo function so I will look into getting a new key and chip and programming it. Hopefully I have immo 2.
The plastic key blade is the emergency wallet key right? It has a chip inside the plastic.
1. No, the door function is not related to immo function.
2, 3: no
3, 4: yes but if immo 3 it has to be a new key.
