Can you adjust the idle rpms on a 2005.5 jetta. Sometimes it has a bad vibration in the car but if you raise the idleing just a little it stops. It say 825 but if you raise it to 900 it stops.I didn't know if you could reprogram and adjust this. Thanks
Yeah ,I changed the flywheel and the clutch was worn out , but it still has a vibaration but not always. I also checked the camshaft and it has signs of wear on a few journals, so when the timing belt is due i will change that also. The car has 143000 miles.
