These two writeups require a VCDS. To use your foglights as DRL you must have foglights from the factory or OEM style retrofit foglight harness. This is because it's controlled from the central electric module. Many people just use an aftermarket relay harness controlled by the low beams to add foglights. Because it's controlled by a relay it won't work as DRL unless you have a euroswitch, move it to the middle position, then pull out to turn on the foglight. This isnt' DRL since it also turns on all the other lights. Also shown is how to disable the DRL and what the Scandinavian DRL is.
http://www.myturbodiesel.com/1000q_how_to/a5/fogDRL.htm
This shows how to reset the memory seat. You can also activate the easy entry/exit function where the seat moves when you enter/exit the car.
http://www.myturbodiesel.com/1000q_how_to/a5/memoryseat.htm
