What do I need to worry about when replacing the injection pump mount on a mk4 tdi? I am replacing the engine in my car, and I bought a used one that has a broken injection pump mount. I have all the parts to do the timing belt replacement at the same time, and I bought the tools, so I do not expect to much trouble with the engine out of the car. I also am replaceing the oil pump and chain.
Thanx
I believe that you have to remove the assembly. It should be easy with engine out of the car.
FYI, there is no writeup on how to replace the oil pump and chain. If you document it with step by step pictures and notes, it will qualify for the writeup contest, the winner's prize is a $50 e-gift certificate to the sponsor kermatdi.com . A step by step pictoral writeup on how to replace the injection pump mount would also qualify.
