I removed the turbo and EGR cooler on my demo engine, if you find the article helpful please use the donation button on the forum and FAQ pages! Here are the 2 DIY articles. Because the engine was out of the car, there may be some additional steps needed like removing an axle or valve cover for clearance. If you do this, please take some pics or at least some notes to flesh out these missing steps, thank you!
Hello. I'm new to the site and have been searching for info on removing the turbo from a CJAA TDI mk6 jetta sportwagen, with the engine still in the vehicle. I've not had any luck so far and wanted to post something on this write up in case someone has knowledge on that job and can shed some light on the task. I have the AllDataDIY subscription (so darn many "refer here" aspects) but I have some general questions it does not answer. I understand the turbo and exhaust manifold are one unit and have to be replaced as a unit... Correct? Does the unit need to be removed from under the vehicle?Does the transaxle or tranny need to removed/disconnected? Can the cool side of the turbo piping be removed to feel the turbine shaft play while still in the engine bay (verify turbo is failing at only 67000 miles)? Any precautions to be aware of in removing/replacing the turbo? Can quality rebuild parts/kits be purchased? Is the dealer turbo the only quality option for a turbo replacement?
My apologies if this is an inappropriate post on the write up.
Before you upgrade the turbo, realize that the turbo is a supporting mod. You have to increase fueling through a chip and maybe a fuel injector upgrade, at which point the turbo becomes needed. On a stock engine with stock programming, an bigger turbo will do nothing other than slightly DECREASE performance because it takes a tiny bit longer to build boost. The other poster's car looks pretty modified - if you plan on future power mods, get a bigger turbo now. If you don't, don't get a bigger turbo.
I figured it must be a performance improvement which I'm not interested in. Been racing and building cars, bikes, qtr midgets, and go carts better part of my life and understand modifications. Have no interest in dealing with that cost and maintenance on a daily driver. Thanks CCBB.
CCBB, looking at your write up on the cjaa turbo removal it looks like removing the single torx screw holding the turbo inlet adapter will expose the turbine so I can feel if it has excess play. Am i correct about the inlet adapter giving access to the turbine?
My 2012 Golf TDI refuse to rev up 2700 RPM at some moment especially at stop. On the road the motor begin to rev up normally with normal power. I have 110 000 km on the motor. The fuel filter was change, the air filter too.
Some idea?
I checked with VAG-COM; no codes.
I'm working on a '11 Jetta. Had multiple codes related to the DPF. Car goes into limp mode pretty quickly. Took the dpf and CAT off and had them professionally cleaned. Codes are still persistent. Is it possible that one of the many sensors of the DPF has failed? Any other hints as to what the...
On my Jetta I am having a problem with the hood not latching when I dropped the hood down. I watch some you tube video's on how to remove the latch assembly. So today I tough I would attack this issue. Well I was able to remove the latch assembly from the car and fix the issue on why the latch...
Hi gents,
I'm having an issue with my 2014 TDi VW Passat.
I can't keep my long beams up , reverse cam doesn't activate and Windshield Washer Pump don't activate.
I'm under impression this would be a relay issue as all 3 don't work . VCDS only gives me an error for Windshield Washer Pump?
I...
