The main difference on changing the rear brake pads or rear brake rotors on a VW Jetta TDI (2006 shown but it will also work on 2005.5-2010 and the cup edition) is that the carrier bolts are triple square (12 point) and that the rotor set screw is now a allen head instead of a phillips.
The full writeup with pictures is below.
http://www.myturbodiesel.com/1000q/a5/rear-brake-pad-rotors-wear-limit-jetta.htm
The only thing to watch out for is that the space for the 15mm carrier nut is narrow so not all open ended wrenches will fit.
