Many thanks to fahrenheit351 for taking pictures of the oil change on his 2010 Audi A3 TDI. Once the engine cover is off it's the same thing.
http://www.myturbodiesel.com/1000q/8p/A3-TDI-oil-change.htm
It uses the same oil filter as earlier A5 Jetta TDI.
On a separate note, I started a collection of FAQ and "how to" for A3 TDI. The common rail Jetta info is currently with the earlier pumpe duse Jetta info because they use the same body. The new collection of FAQ for the A3 TDI excludes Jetta specific info and will have stuff added to it as it comes up. On a separate note I fixed a forum problem, the FAQ index for A5 Jetta are now back.
