1 - 20 of 252 Posts
So far, the 2012 VW Passat is not available with LED running lights, taillights, or HID headlights. If you look at the buying guide: http://www.myturbodiesel.com/1000q/b7/2012-vw-passat-tdi-forum-buying-guide.htm , you'll see that the North American Passat is nothing like the European Passat which does have these options. Therefore, the Euro parts cannot be added.
However, the Chinese VW Passat which is based off the NA Passat will! Even the Sagitar (mk5 Jetta) usually came with options that you couldn't get in North America like park assist. This is because VW is considered an upper-middle car. In other words, not driven by a chauffeur and attainable by upwardly mobile educated class but still expensive.
It's not yet known if it's plug-play because of the control modules for the auto leveling and cornering but it shouldn't be too far off. Here is a picture of the China Passat. And yes, they drive on the right side of the road (left hand drive) so the headlights will be aimed properly.
Their car also comes with a full color MFD but since they use kilometers it won't be usable except in Canada. You can change languages but since Western is different text than Chinese characters, I don't know if you can change languages to English.
The LED taillights should also work but again, they may not be plug-play.
Some other differences are that the China Passat has the electronic parking brake (I don't like this since it adds unsprung weight to the rear caliper) and park assist.
Their website doesn't say. It just says New Passat.
If there was enough interest in the headlights or taillights I might be able to set up a group buy but I would have to figure out what my cost is. There's no way I would tie up thousands of dollars in inventory and import the parts unless I could make money off it. But that is barring them not being available from another source who could import those parts.
Hmm.. I was wondering if there would be an option to retrofit the '11 Golf HIDs to the rumored '12 Golf HIDs with LEDs. I already have the leveling hardware and circuits.
Any info on that?
Discussion Starter · #5 ·
Any info on that?
First, the 2012 Golf HID will have LEDs. I'm not a huge fan of their implementation (dots of light) because it looks somewhat aftermarket. I prefer the Audi's ribbon LED light. I think they achieve the effect by having a diffuser strip in front of the LEDs because I can see some "hot spots" and strips where the light is diffused.
Second, the parts catalog was just updated to include the 2012 Golf LED headlights. As far as I know, this is the first mention of the part numbers. Attached are the parts diagram for your style and the new 2012 LED daytime running lights. The part numbers below are the US spec headlights (DOT approved). You might be able to buy the Euro headlights online later but you can only buy the US spec parts from the dealer in the US. The left side is 5k0 941 753 c (5k0941753c), the right side is 5k0 941 754 c (5k0941754c).
The plug is the exact same but that doesn't mean the wiring is the same. Worst case, you have to run a few wires.
It looks like the mounting bracket for the headlight is slightly different. However, even if it's not compatible, you just have to replace the bracket that it sits on, part #15.
Part #3 on the LED equipped HID housing is not on your headlights but it should come with the new style as part of the assembly.
There might be a small difference in the central electric control module to use the LED daytime running lights instead of the stock DRL.
Invoice price for the headlights is about 460 or 533 (the retail price or internet wholesale price would be about $600-700 for each assembly).
Discussion Starter · #6 ·
Back to our originally scheduled programming....here are the part numbers for the China Passat Xenon HID headlight retrofit.
To make them work, you'd have to do some VCDS work to change the coding at a minimum. To make them work like OEM (auto leveling and dynamic cornering) you'd have to add the self leveling sensors on the suspension, the cornering module, and the associated wiring. This assumes that it's compatible with the electronic control system. Until someone looks at the coding for North American spec Passat to see if it's possible, I don't even know if you can make it work even if you added the control modules and leveling sensor.
Obviously they are not DOT approved but since China is also left hand drive (drive on the right side of road), the beam pattern should be correct. The left is 56d 941 753 (56d941753) and the right HID is 56d 941 754 (56d941754).
:thumbsup I like the LEDs. They save headlight bulb wear and tear and they're still very distinctive. If you see a Honda Civic with them, yes they look aftermarket but it's all in the execution.
I'm sorry for thread barging. I should have started a new one.
Honestly though, I do appreciate all the information you provided. Thanks.
i would def. be interested in bi-xenons on a 2012 Passat. It's unfortunate that VW is going a different direction with their cars in this country to undercut Honda/Toyota. All the cool luxury items should be available as options, what a let down!
Sweet information!! I definitely would want to do this, wonder if you can set them up without the cornering and self leveling. That would save some work and wiring for sure.
:+1
LED tail lights
Does any one have or know the part numbers for the LED tail lights?
I would like to get a set for my 2012 Passat
thanks,
I got hold of an AutoScan from a Chinese Passat and it is quite a bit different than the US ones. Almost no control modules are identical. That's not to say retrofits wouldn't work, but they would definitely be uncharted territory for early-adopter types. Here's the Chinese one followed by a US TDI SEL:
Hey, Andy
I have one Chinese NMS auto-scan for now (With Xenon):
Code:
CDS版本: ZHS 10.6.3
数据版本: 20110106
星期五,13,五月,2011,10:54:47:39956
底盘类型: 7N0
扫描: 01 02 03 08 09 10 15 16 17 19 25 37 42 44 46 4F 52 53 55 56
          62 72 77
车辆识别号: LSVCD6A43BNxxxxxx
01-发动机-- 状态: 个别通讯错误1000
02-自动变速箱-- 状态: 发生故障0010
03-ABS制动-- 状态: 发生故障0010
04-转向角-- 状态: 正确0000
08-空调/加热系统-- 状态: 发生故障0010
09-中央电气系统-- 状态: 发生故障0010
10-驻车/转向辅助-- 状态: 正确0000
15-安全气囊-- 状态: 正确0000
16-方向盘-- 状态: 正确0000
17-仪表板-- 状态: 发生故障0010
19-CAN网关-- 状态: 发生故障0010
25-防启动锁-- 状态: 正确0000
37-导航系统-- 状态: 正确0000
42-驾驶员侧车门-- 状态: 发生故障0010
44-转向助力-- 状态: 发生故障0010
46-中央舒适系统-- 状态: 正确0000
4F-中央电气系统II -- 状态: 正确0000
52-乘客侧车门-- 状态: 发生故障0010
53-驻车制动-- 状态: 发生故障0010
55-氙灯射程-- 状态: 发生故障0010
56-收音调谐器-- 状态: 正确0000
62-左后车门控制-- 状态: 正确0000
72-右后车门-- 状态: 正确0000
77-电话-- 状态: 正确0000
地址01: 发动机(CEA)       标签: 无
   零件号 软件: 06J 906 027 AL    硬件: 06J 907 309 A
   组件: MED17.5.2        01 8498
   版本: P3H06---    序列号:
   编码: 0404000324070160
   服务站代码: WSC 00078 790 00193
   VCID: 75EA36696547
未发现故障码。
就绪状态: 0000 0000
地址02: 自动变速箱        标签: ZHS\0AM-300-04x.clb
   零件号 软件: 0AM 300 050 E    硬件: 0AM 927 769 D
   组件: GSG DSG AG7     403 2325
   版本: 00040034    序列号: 5ZV01005260044
   编码: 0000020
   VCID: 2B5ED011F383
找到1 个故障码:
006224 - 数据总线传动系: 发动机控制发出的信息缺失
               P1850 - 000 -  -  - 间歇
             故障发生环境要求:
                    故障状态: 00100000
                    故障优先级: 0
                    故障频率: 1
                    自动重置计数器: 3
                    里程: 1672 km
                    时间标志: 0
                    日期: 2002.14.23
                    时间: 09:06:51
地址03: ABS制动(J104)       标签: 无
   零件号 软件: 561 907 379 B    硬件: 561 907 379 B
   组件: ESP MK60EC1   H26 0105
   版本: 00H26001
   编码: C54BC8F6092B00FAA30B13E490190049360000
   服务站代码: WSC 00078 790 00198
   VCID: 21423239814F
3 个故障码已找到:
01314 - 发动机控制单元
            004 -  无通讯信号- 间歇
             故障发生环境要求:
                    故障状态: 00100100
                    故障优先级: 2
                    故障频率: 1
                    自动重置计数器: 68
                    里程: 1672 km
                    时间标志: 0
                    日期: 2002.14.23
                    时间: 09:06:51
             故障发生环境要求:
                    计数: 0
                    计数: 14
                    计数: 28672
                    计数: 8194
                    计数: 40448
                    计数: 1024
                    计数: 0
                    计数: 0
01325 - 轮胎压力监控器控制单元
            004 -  无通讯信号- 间歇
             故障发生环境要求:
                    故障状态: 00100100
                    故障优先级: 2
                    故障频率: 1
                    自动重置计数器: 68
                    里程: 1672 km
                    时间标志: 0
                    日期: 2002.14.23
                    时间: 09:07:01
             故障发生环境要求:
                    计数: 2
                    计数: 14
                    计数: 28672
                    计数: 16390
                    计数: 40448
                    计数: 1024
                    计数: 0
                    计数: 0
02214 - 轮胎压力警告
            002 -  低于下限值- 间歇
             故障发生环境要求:
                    故障状态: 00100010
                    故障优先级: 2
                    故障频率: 1
                    自动重置计数器: 80
                    里程: 1679 km
                    时间标志: 0
                    日期: 2002.14.27
                    时间: 13:04:47
             故障发生环境要求:
                    计数: 0
                    计数: 32768
                    计数: 4096
                    计数: 16401
                    计数: 49410
                    计数: 0
                    计数: 520
                    计数: 0
地址08: 空调/加热系统 (J255)       标签: 无
   零件号 软件: 561 907 044 B    硬件: 561 907 044 B
   组件: Climatronic   H01 0101
   版本: 00001001
   编码: 0000002102
   ASAM数据库名: EV_ACClimaBHBVW411 A01001
   ROD: 不可用
   VCID: 162811E55801
   零件号 软件: 561 907 049 A    硬件: 561 907 049 A
   组件: KBT-H  H08 0008
   序列号: 20101216000000000006
无ASAM数据: "EV_ACClimaBHBVW411" (VW36)
找到1 个故障码:
13701376 - ROD - 未知错误代码
             故障发生环境要求:
                    故障状态: 00000001
                    故障优先级: 6
                    故障频率: 1
                    自动重置计数器: 67
                    里程: 1672 km
                    日期: 2002.14.23
                    时间: 09:06:52
地址09: 中央电气系统(J519)       标签: ZHS\1K0-937-08x-09.clb
   零件号 软件: 5K0 937 087 N    硬件: 5K0 937 087 N
   组件: BCM PQ35 H+   011 0046
   版本: BF011001
   编码: 66000A3B802D1AD44008008091008B704375978870A08964018000200840
   VCID: 408497BD6A05
   零件号: 1K0 955 559 AH
   组件: RLS 080910 05  54  0403
   编码: 03300A
找到1 个故障码:
01038 - 中控锁过热保护
            000 -  -  - 间歇
             故障发生环境要求:
                    故障状态: 00100000
                    故障优先级: 6
                    故障频率: 1
                    自动重置计数器: 84
                    里程: 2198 km
                    时间标志: 0
                    日期: 2003.14.21
                    时间: 09:36:05
             故障发生环境要求:
                        端子15关
                    电压: 12.15 V
                        断开
                        接通
                        断开
                        断开
                        断开
地址10: 驻车/转向辅助(J791)       标签: ZHS\3C8-919-475.clb
   零件号 软件: 35D 919 475 B    硬件: 3T0 919 475 C
   组件: PARKHILFE PLA H08 0203
   版本: --------    序列号: --------------
   编码: 30810F
   VCID: 3162C279D1AF
未发现故障码。
地址15: 安全气囊(J234)       标签: 无
   零件号 软件: 56D 959 655     硬件: 56D 959 655
   组件: VW10Airbag003 H01 0001
   版本: --------    序列号: 003JK2T004NE
   编码: 000000000000000000000000000000003033
   服务站代码: WSC 64250 381 2056031
   ASAM数据库名: EV_AirbaVW10BPAVN750 A01026
   ROD: 不可用
   VCID: F6E8B165F841
无ASAM数据: "EV_AirbaVW10BPAVN750" (VW36)
未发现故障码。
地址16: 方向盘(J527)       标签: ZHS\5K0-953-569.clb
   零件号 软件: 1K5 953 507 T    硬件: 5K0 953 549 B
   组件: Lenks.Modul   008 0080
   版本: --------    序列号: WHRPIturHHHI?
   编码: 088A140000
   服务站代码: WSC 00078 790 00171
   ASAM数据库名: EV_SMLSNGKUDS A05001
   ROD: EV_SMLSNGKUDS_VW36.rod
   VCID: 42809DB56409
   MFL:
   零件号 软件: 56D 959 537     硬件: 56D 959 537
   组件: E221__MFL-TK6  H06 0022
   序列号: 70000000000000130396
   编码: E20000
未发现故障码。
地址17: 仪表板(J285)       标签: 无
   零件号 软件: 56D 920 880     硬件: 56D 920 880
   组件: KOMBI         H06 0307
   序列号: 00000000000000
   编码: 131E01
   ASAM数据库名: EV_Kombi_UDS_VDD_RM09 A04093
   ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
   VCID: EAD09515BCF9
找到1 个故障码:
12648448 - 由于信息缺失而造成功能受限
          U1111 00 [008] -  -
             故障发生环境要求:
                    故障状态: 00000001
                    故障优先级: 6
                    故障频率: 1
                    自动重置计数器: 67
                    里程: 1672 km
                    日期: 2002.14.23
                    时间: 09:06:51
地址19: CAN网关(J533)       标签: ZHS\7N0-907-530-V2.clb
   零件号 软件: 7N0 907 530 D    硬件: 1K0 907 951
   组件: J533  Gateway H35 0614
   版本:   H35       序列号: 220710F1002291
   编码: 461000
   服务站代码: WSC 00078 790 00176
   VCID: 3162C279D1AF
找到1 个故障码:
01314 - 发动机控制单元
            004 -  无通讯信号- 间歇
             故障发生环境要求:
                    故障状态: 00110100
                    故障优先级: 2
                    故障频率: 1
                    自动重置计数器: 67
                    里程: 1672 km
                    时间标志: 0
                    日期: 2002.14.23
                    时间: 09:06:52
地址25: 防启动锁(J334)       标签: ZHS\5K0-920-xxx-25.clb
   零件号 软件: 5K0 953 234     硬件: 5K0 953 234
   组件: IMMO          H06 0307
   序列号:
   编码: 000000
   ASAM数据库名: EV_Immo_UDS_VDD_RM09 A03009
   ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
   VCID: EAD09515BCF9
未发现故障码。
地址37: 导航系统(J0506)       标签: 无
   零件号 软件: 56D 035 682     硬件: 56D 035 682
   组件: RNS-MID       H50 0878
   序列号: VWZ6Z7K4336083
   编码: 00000442040000A4000B
   ASAM数据库名: ------------------------- ------
   VCID: E7D6EC21AFEB
未发现故障码。
地址42: 驾驶员侧车门(J386)       标签: 无
   零件号 软件: 56D 959 701     硬件: 3C0 959 793 B
   组件: TUER-SG FT    002 0503
   版本: 13110009    序列号: 0001492978
   编码: 0404F5
   ASAM数据库名: EV_TSGFPQ25BRFVW46X A04001
   ROD: EV_TSGFPQ25BRFVW46X.rod
   VCID: EED899058011
   Slave Driver:
   零件号 软件: 561 959 811     硬件: 561 959 811
   组件: J388__TSG_HL  002 4491
   序列号: --------------------
   编码: 000000
找到1 个故障码:
68108 - 由于信息缺失而造成功能受限
          U1111 00 [008] -  电路有故障
             故障发生环境要求:
                    故障状态: 00000001
                    故障优先级: 6
                    故障频率: 1
                    自动重置计数器: 67
                    里程: 1672 km
                    日期: 2002.14.23
                    时间: 09:06:51
地址44: 转向助力        标签: ZHS\1Kx-909-14x.clb
   零件号: 1K0 909 144 J
   组件: EPS_ZFLS Kl. 196    3001
   版本: 00H17000
   服务站代码: WSC 00078 790 00182
   VCID: 3162C279D1AF
找到1 个故障码:
01314 - 发动机控制单元
            004 -  无通讯信号- 间歇
             故障发生环境要求:
                    故障状态: 00100100
                    故障优先级: 3
                    故障频率: 1
                    自动重置计数器: 67
                    里程: 1672 km
                    时间标志: 0
                    日期: 2002.14.23
                    时间: 09:06:51
             故障发生环境要求:
                    电压: 11.25 V
                        DU
                    温度: 14.0*C
                    发动机转速: 1498 /min
                    车速: 0.0 km/h
                    车速: 0.0 km/h
                    计数: 0
地址4F: 中央电气系统II (J520)       标签: 无
   零件号 软件: 7N0 907 532     硬件: 1K0 907 951
   组件: EZE_2         H35 0614
   编码: 01030108
   VCID: EFE68401871B
   零件号 软件: 561 959 591     硬件: 561 959 591
   组件: J245 P05 FFD7  H07 0004
   编码: 181100
   零件号 软件: 561 919 204     硬件: 561 919 204
   组件: Analoguhr  X06 X002
未发现故障码。
地址52: 乘客侧车门(J387)       标签: 无
   零件号 软件: 56D 959 702     硬件: 3C0 959 792 B
   组件: TUER-SG BT    002 0503
   版本: 15110009    序列号: 0001493202
   编码: 0404F4
   ASAM数据库名: EV_TSGBPQ25BRFVW46X A04001
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: EFE68401871B
   Slave Passenger:
   零件号 软件: 561 959 812     硬件: 561 959 812
   组件: J389__TSG_HR  002 4491
   编码: 000000
找到1 个故障码:
             故障发生环境要求:
                    故障状态: 00000001
                    故障优先级: 6
                    故障频率: 1
                    自动重置计数器: 67
                    里程: 1672 km
                    日期: 2002.14.23
                    时间: 09:06:51
地址53: 驻车制动(J540)       标签: 无
   零件号 软件: 56D 907 801 A    硬件: 56D 907 801
   组件: EPB-4         H03 0004
   版本: --------    序列号: 00000000000332
   编码: 0F3C55
   ASAM数据库名: EV_ParkiBrakeTRWVW411 002007
   ROD: 不可用
   VCID: 29522A19F97F
无ASAM数据: "EV_ParkiBrakeTRWVW411" (VW36)
5 个故障码已找到:
333568 - ROD - 未知错误代码
             故障发生环境要求:
                    故障状态: 00000001
                    故障优先级: 6
                   故障频率: 1
                    自动重置计数器: 67
                    里程: 1672 km
                    日期: 2002.14.23
                    时间: 09:06:50
334080 - ROD - 未知错误代码
             故障发生环境要求:
                    故障状态: 00000001
                    故障优先级: 6
                    故障频率: 1
                    自动重置计数器: 67
                    里程: 1672 km
                    日期: 2002.14.23
                    时间: 09:06:50
327936 - ROD - 未知错误代码
             故障发生环境要求:
                    故障状态: 00000001
                    故障优先级: 6
                    故障频率: 1
                    自动重置计数器: 67
                    里程: 1672 km
                    日期: 2002.14.23
                    时间: 09:06:50
331264 - ROD - 未知错误代码
             故障发生环境要求:
                    故障状态: 00000001
                    故障优先级: 6
                    故障频率: 1
                    自动重置计数器: 67
                    里程: 1672 km
                    日期: 2002.14.23
                    时间: 09:06:50
331520 - ROD - 未知错误代码
             故障发生环境要求:
                   故障状态: 00000001
                    故障优先级: 6
                    故障频率: 1
                    自动重置计数器: 67
                    里程: 1672 km
                    日期: 2002.14.23
                    时间: 09:06:50
地址55: 氙灯射程        标签: ZHS\5M0-907-357.clb
   零件号 软件: 5M0 907 357 D    硬件: 5M0 907 357 D
   组件: AFS-Steuergeraet    0149
   版本: 00H04000    序列号:
   编码: 7472341
   VCID: 356AF66925C7
   零件号: 3TD 941 329
   组件: AFS-Lst.-Modul l    0002
   编码: 00000114
   零件号: 3TD 941 329
   组件: AFS-Lst.-Modul r    0002
   编码: 00000114
找到1 个故障码:
01314 - 发动机控制单元
            004 -  无通讯信号- 间歇
             故障发生环境要求:
                    故障状态: 00100100
                    故障优先级: 6
                    故障频率: 1
                    自动重置计数器: 67
                    里程: 1672 km
                    时间标志: 0
                    日期: 2002.14.23
                    时间: 09:06:51
             故障发生环境要求:
                    电压: 11.08 V
                    车速: 0.0 km/h
                        ABS 1
地址56: 收音调谐器(J0506)       标签: 无
   序列号: VWZ6Z7K4336083
   VCID: E7D6EC21AFEB
未发现故障码。
地址62: 左后车门控制
无法进入
地址72: 右后车门
无法进入
地址77: 电话(J738)       标签: ZHS\1K8-035-730.clb
   零件号 软件: 1K8 035 730 D    硬件: 1K8 035 730 D
   组件: Telefon       H08 6900
   版本: 00008000    序列号: 00000A07781246
   编码: 412120
   VCID: 2A50D515FC79
未发现故障码。
结束   --------------------------------------------------------------------
And a US TDI SEL:
Sunday,17,July,2011,09:53:37:04876
VCDS Version: Beta 11.3.0
Data version: 20110601
Chassis Type: 7N0
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 47 4F
52 56 62 72 77
VIN: 1VWCN7A37CCxxxxxx
05-Acc/Start Auth. -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CKRA) Labels: None
Part No SW: 03L 906 012 BP HW: 03L 907 309 S
Component: R4 2,0L EDC H20 1784
Revision: 71H20--- Serial number:
Coding: 001D0012042400008000
Shop #: WSC 09003 957 00200
ASAM Dataset: EV_ECM20TDI01103L906012BP 004002
ROD: N/A
VCID: 73EEC0E46E90
No ASAM data for: "EV_ECM20TDI01103L906012BP" (VW36)
1 Fault Found:
5523 - ROD - Unknown Error Code
- MIL ON
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 2
Mileage: 51 km
Date: 2001.14.15
Time: 13:46:03
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 054 C HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2803
Revision: 05351112 Serial number: 00001011290315
Coding: 0000020
VCID: 1628D9705DA2
No fault code found.
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: C54BC0F5492200FCA30B03EC921D0042A70000
VCID: 7BFEE8C446C0
Address 05: Acc/Start Auth. (J518) Labels: 5K0-959-434.clb
Part No SW: 5K0 959 434 A HW: 5K0 959 434 A
Component: VWKESSYPQ35GP 085 0802
Revision: 00085000 Serial number: 0143544223
Coding: 130C0C
ASAM Dataset: EV_KESSY_PQ35GP A01018
ROD: EV_KESSY_PQ35GP_VW36.rod
VCID: 336E00E42E10
1 Fault Found:
1057547 - Antenna for Keyless Entry System; Interior Antenna 1
B1172 13 [008] - Reserved by ISO 15031-6:2005
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 44
Mileage: 31 km
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 561 907 044 D HW: 561 907 044 D
Component: Climatronic H01 0102
Revision: 00001001
Coding: 0010001012
ASAM Dataset: EV_ACClimaBHBVW411 A01001
ROD: EV_ACClimaBHBVW411.rod
VCID: 1834D74857B6
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 087 Q HW: 5K0 937 087 Q
Component: BCM PQ35 H+ 111 0147
Revision: BL111001
Coding: 6F200E1B982B02D408880201360085480071008645A005F064806000BC70
VCID: 438E50247EB0
Subsystem 1 - Part No: 1K0 955 559 AH
Component: RLS 160211 05 54 0403
Coding: 22300A
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5C0 959 655 HW: 5C0 959 655
Component: AirbagVW10G 013 0809
Serial number: 003END090A0T
Coding: 00003548
Shop #: WSC 86098 666 04556
ASAM Dataset: EV_AirbaVW10SMEVW360 A01024
ROD: EV_AirbaVW10SMEVW360_VW36.rod
VCID: EFE64C9482B8
Seat occupied recognition:
Subsystem 1 - Part No SW: 5C6 959 339 HW: 5C6 959 339
Component: BF-Gewichtss. H10 0027
Serial number: 6940000Y11000029GG0C
Coding: 303252
Driver's Airbag Crash Sensor:
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME1923455CZZZY
Passenger Side Airbag Crash Sensor:
Subsystem 3 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME7F06445EZZZ6
Driver's Rear Airbag Crash Sensor:
Subsystem 4 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Fahr.H H02 ----
Serial number: 3516KSME074F200EZZZV
Passenger's Rear Airbag Crash Sensor:
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Beif.H H02 ----
Serial number: 3526KSME00293710ZZZC
Driver's Front Airbag Crash Sensor:
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Fahr H02 ----
Serial number: 3556LSME00475F0DZZZ
Passenger's Front Airbag Crash Sensor:
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Beif H02 ----
Serial number: 3566LSME3B143C0FZZZ1
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 1K5 953 521 AR HW: 5K0 953 569 E
Component: LENKS.MODUL 014 0140
Revision: FF010040 Serial number: 20110404201168
Coding: 100A140000
ASAM Dataset: EV_SMLSNGVOLWSXS A01004
ROD: EV_SMLSNGVOLWSXS_VW36.rod
VCID: 7DFAE6DC58D4
MFL:
Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D
Component: E221__MFL-YVJ H06 0022
Coding: E20000
Address 17: Instruments (J285) Labels: None
Part No SW: 561 920 970 C HW: 561 920 970 C
Component: KOMBI H07 0507
Serial number: 00000000000000
Coding: 231E01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04093
VCID: 1A30CD40A9BA
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 D HW: 1K0 907 951
Component: J533 Gateway H35 0614
Revision: H35 Serial number: 14031101200750
Coding: 461000
VCID: 31620AECD40C
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H07 0507
Serial number:
Coding: 000007
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
VCID: EAD05D80B95A
Address 2B: Steer. Col. Lock (J764) Labels: 5K0-905-861.clb
Part No SW: 5K0 905 861 A HW: 5K0 905 861 A
Component: ELV-PQ35 H20 0220
Revision: 00000000 Serial number: 10000069527005
Coding: 4900000000000000
ASAM Dataset: EV_ELVMarquMPVW36X A01001
ROD: EV_ELVMarquMPVW36X_VW36.rod
VCID: 2E581190C532
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Component: SG EXT.PLAYER H13 0240
Revision: A1001003 Serial number: 7669629590
Coding: 010000
VCID: 2952E28CFCDC
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 561 959 760 HW: 561 959 760
Component: MEM-FS H04 0181
Revision: AA000000 Serial number: 00001002197065
Coding: 00581B0000000000000021010100202020202120202020
VCID: E0C43FA84F66
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 3C0 035 684 E HW: 3C0 035 684 E
Component: RNS-MID H07 2625
Revision: AB001001 Serial number: VWZ6Z7L7113100
Coding: 04090002010000A4000B
ASAM Dataset: ------------------------- ------
VCID: 254AEEBC90C4
Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 561 959 701 A HW: 3C0 959 793 C
Component: TUER-SG FT 002 0523
Revision: 12110009 Serial number: 0002192761
Coding: 0405FD
ASAM Dataset: EV_TSGFPQ25BRFVW46X A04001
VCID: 1C3CCB58A38E
Slave Driver:
Subsystem 1 - Part No SW: 561 959 811 HW: 561 959 811
Component: J388__TSG_HL 004 4472
Serial number: --------------------
Coding: 800000
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 197 3201
Revision: 00H20000
Shop #: WSC 01357 011 00200
VCID: 346C03F82B1E
Address 47: Sound System (R12) Labels: 3T0-035-456.clb
Part No SW: 3T0 035 456 B HW: 3T0 035 456 B
Component: KonzernAmp10K H06 0362
Revision: -------- Serial number: BP225309711034
ASAM Dataset: EV_AudioVerst10KanalSTT3 S01001
ROD: EV_AudioVerst10KanalSTT3.rod
VCID: 30640FE8DF06
Address 4F: Centr. Electr. II (J520) Labels: None
Part No SW: 7N0 907 532 HW: 1K0 907 951
Component: EZE_2 H35 0614
Coding: 01030108
VCID: EFE64C9482B8
Subsystem 1 - Part No SW: 561 959 591 HW: 561 959 591
Component: J245 P05 FFD7 H07 0004
Coding: 181100
Subsystem 2 - Part No SW: 561 919 204 B HW: 561 919 204 B
Component: Analoguhr 008 0002
Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 561 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0523
Revision: 14110009 Serial number: 0002156253
Coding: 0405FC
ASAM Dataset: EV_TSGBPQ25BRFVW46X A04001
VCID: 1D3AC65CB894
Slave Passenger:
Subsystem 1 - Part No SW: 561 959 812 HW: 561 959 812
Component: J389__TSG_HR 004 4472
Coding: 800000
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
VCID: 254AEEBC90C4
Address 62: Door, Rear Left
Cannot be reached
Address 72: Door, Rear Right
Cannot be reached
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 F HW: 7P6 035 730 F
Component: TELEFON H09 2730
Revision: 1B001001 Serial number: 00007669739760
Coding: 0A01000000010110
ASAM Dataset: EV_UHVNA A01015
ROD: EV_UHVNA_VW52.rod
VCID: 356A3EFC2064
End ---------------------------------------------------------------------
Discussion Starter · #16 ·
Someone asked me what the part number for the Chinese LED taillights are, it's
left inner: 56d 945 093 a
left outer:56d 945 095 a
right inner:56d 945 094 a
right outer:56d 945 096 a
The 2013 CC is due in Spring..
It has a beautiful HID-LED headlights...
Maybe this will be a easier retrofit project...
Keep me the in the loop too.
1 - 20 of 252 Posts
