Hello i am from hamilton , ontario, canada and have a 2001 jetta tdi , its stock has 350,000 kms on i just had the clutch done , a southbend stage 2 and i am having some issues. The clutch was perfect when installed but when i pulled my belly pan off oil was everywhere.... rear main seal leaking. Went back to the shop i had do the clutch and they changed the seal again , it also leaked so they pulled the tranny a third time and put in the old style rubber seal with spring.I don,t think it is leaking now but i have a vibration when i press the pedal in when the car is moving felt in clutch pedal. also when i put it in neutral now i get a lot of noise from the transmission - clutch and when it gets warm my shifter sticks esspecially if i have driven it harder. I adjusted the linkage and am using redline mt90 oil. Was perfect before they took the tranny out so many times. Not sure what to do now.
Check the gearbox oil level and make sure it's been topped up, it sounds like it might be that.:)
welcometomyturbodies
i did recheck the oil in transmission it is full , i thought the same thing but nope , not it.thanks anyways.
